Old 27-02-2009, 01:20 PM   #1 (permalink)
Arrow XEN Virtual Machine on OpenSUSE 11.1 [Processor does not support full virtualization]
Hi
i have SUSE 11.1 64 bit, Phenom 9550 and gigabyte 780G motherboard. In one of the hard disk i have installed windows XP. Now when I create a virtual machine for windows XP using XEN it throws "Processor(s) does not support full virtualization". I have booted using the XEN kernel. I want to know whether any of you have created a windows XP virtual machine using XEN in linux. if so please help me in resolving this problem
regards
squid is offline
Old 01-03-2009, 04:52 PM   #2 (permalink)
mekalodu
iinfi's Avatar
Default Re: XEN Virtual Machine on OpenSUSE 11.1 [Processor does not support full virtualizat
i think you have to enable virtualization in BIOS. i m not too sure though
is there an option of paravirtualized in open suse? if there is one, then you should be able to install winxp using the paravirtualized option.
iinfi is offline
Old 02-03-2009, 07:01 AM   #3 (permalink)
BSD init pwns System V
hellknight's Avatar
Yeah.. i think that your processor supports virtualization coz i'm using Athlon X2 which supports too.. try changing your BIOS settings and post the results
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 04-03-2009, 07:07 PM   #4 (permalink)
thanks for the reply. I have enabled the virtualization option in BIOS and now it's working. I have already installed windows XP in /dev/sdd1 and now the virtual console is just showing booting from harddisk. Is there any other parameter i have to specify
please help
attached screenshot
squid is offline
Old 04-03-2009, 10:09 PM   #5 (permalink)
mekalodu
iinfi's Avatar
could you please post another screen shot or be more precise? the attachment is not viewable. i dont think the attachments in this forum work.
you can post screen shots through http://imageshack.us/
btw are you able to boot into winxp?
c if this link helps http://www.linuxtopia.org/online_boo...virt-lab1.html
iinfi is offline
Old 05-03-2009, 09:57 AM   #6 (permalink)
I have uploaded the image in imageshack
http://img87.imageshack.us/img87/9930/xenc.jpg
Win Xp can be booted normally and i am using it till date
Linux is installed in dev/sdc1 and winxp in dev/sdd1
http://img27.imageshack.us/img27/6803/hardinfo.jpg
squid is offline
Old 05-03-2009, 11:50 PM   #7 (permalink)
mekalodu
iinfi's Avatar
well,
i m sorry i m not too sure as to what you are looking for. my exp in this field is limited. once you get a boot from hard disk does it hang or something or windows xp boots properly. if it does boot properly i dont see any harm in it.
iinfi is offline
Old 06-03-2009, 06:10 AM   #8 (permalink)
Dark Star's Avatar
Go to more processor option in Advance Overclocking section and activate Virtualization !
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 06-03-2009, 01:24 PM   #9 (permalink)
hi
I want to run windows xp as a virtual machine in Linux. Till now i was dual booting and if i have to work in windows i have to restart the machine and log on to XP and vice versa. I want to work in both linux and windows simultaneously so that i need not reboot the system.
The problem here is I could not boot into windows XP from this virtual machine inside linux. The tight vnc window just shows 'booting from Hard Disk' and stays there forever. There is some sort of conflict which i could not resolve myself.
Whether i have to look for other softwares such as vmware or virtual box
please suggest
--Dark Star
I have already enabled virtualization option in the BIOS and please tell me where i have to look for this advanced overclocking section
squid is offline
Old 08-03-2009, 03:22 AM   #10 (permalink)
mekalodu
iinfi's Avatar
sry i dont know whats causing the trouble.
chk on forums on novell website whether you get any help.
if you are able to solve it plz do let us know
iinfi is offline
Old 28-03-2009, 05:54 PM   #11 (permalink)
Always confused
vamsi360's Avatar
Smile Re: XEN Virtual Machine on OpenSUSE 11.1 [Processor does not support full virtualizat
to run Hyper-V hardware virtualization on Windows Server 2008 too you need special vitualization technology processors from Intel (the series ending with v tag) and AMD virtualization processors.
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline
Symbian in a Virtual Machine MetalheadGautham Mobiles and Tablets 17 29-01-2009 10:45 AM
Virtual machine driver INS-ANI Software Q&A 2 28-02-2008 08:55 PM
Virtualization in Linux: Parallels virtualization software is now available in Ubuntu subratabera Open Source 10 14-02-2008 11:40 PM
Virtual Machine Charan Open Source 6 14-12-2007 12:32 AM
Setting Virtual Machine ? guru QnA (read only) 14 16-06-2007 06:43 PM
