Old 07-06-2005, 01:08 PM   #1 (permalink)
Default Knoppix without CD?
hi guyz,
i want 2 download knoppix3.9, but i have older knoppixes...
I would like to know how i could run knoppix with burning the .iso file?
I have XP SP2 and SuSe Linux 9.1
Is there a way?
vij26 is offline
Old 07-06-2005, 03:04 PM   #2 (permalink)
I've tried knoppix once. When booting, set CDROM as first boot device. Insert your knoppix CD in drive before computer boots. (I mean Windows XP boots)
Knoppix will boot automaticly. You can use it this way. But you can't eject CD without shutting down knoppix.
Delta is offline
Old 07-06-2005, 04:32 PM   #3 (permalink)
tuxfan's Avatar
vij26, your question is not too clear. What do you want to do? Are you trying to save a CD by booting directly from the .iso file on the hard disk?
tuxfan is offline
Old 07-06-2005, 05:06 PM   #4 (permalink)
trigger's Avatar
after burning the cd boot with that cd & that 's all i think ....
trigger is offline
Old 07-06-2005, 11:40 PM   #5 (permalink)
topic name and the question asked has no relation, plz be apt in naming them ... btw u can use knoppix with cd as a default if u want in hdd , type "knx2hd" (in terminal/konsole)
Hibernating ....
banned2wise is offline
Old 10-06-2005, 06:19 PM   #6 (permalink)
vignesh's Avatar
I think he wants to use knoppix without the cd.You can install knoppix and then use it like anormal distrubution.I think the code is
su
knoppix -installer
vignesh is offline
Old 14-06-2005, 04:39 PM   #7 (permalink)
in konsole
type knx-hdinstall
follow instructions
who the hack is this??
mukul is offline
Old 14-06-2005, 05:33 PM   #8 (permalink)
Uh ... I think he wants to try out the knoppix live linux without having to burn the downloaded file to a CD
@vij21 - do you have access to a DOS drive? A bootable DOS floppy or Win9x will do ... basically you can use a tool called loadlin to boot into the knoppix CD kernel. Check the Tips & Tricks sticky for info. I don't have knoppix anymore so I can't tell you the exact steps. But look in the ISO for the kernel and the initrd image.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 14-06-2005, 08:44 PM   #9 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: Knoppix without CD?
He has written with clearly, but IMHO he meant to say without
i think loadlin would do the trick.
First he needs to copy the 600MB KNOPPPIX file and knoppix's kernel separately to the harddisk and add its entry to the boot loaderr..
http://web.gnuer.org
GNUrag is offline
