Old 25-02-2009, 06:45 AM   #1 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
Default Help needed with ethernet connection
I am currently using Ubuntu 8.10 and everything was fine till yesterday. But today when I started my computer, it is not connecting to internet.
I use Asianet cable connection through ethernet. The motherboard model is Asus P5KPL-CM.
Friends, till yesterday everything was fine but today no connection in Ubuntu. I am posting through Windows so the network port doesn't have any problems.
Help me please
If you want to be happy, be.
shivkumar is offline
Old 25-02-2009, 10:50 AM   #2 (permalink)
fabler's Avatar
Default Re: Hwlp needed with ethernet connection
are you using broadband connection ? check your IP settings once...
fabler is offline
Old 25-02-2009, 01:47 PM   #3 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
its broadband connection... ip address assigned by DHCP.
Old 25-02-2009, 01:50 PM   #4 (permalink)
damnbadman666
damngoodman999's Avatar
ok refresh the network config , restart the network by
service network restart
chkconf network on
do this in the terminal
damngoodman999 is offline
Old 25-02-2009, 01:53 PM   #5 (permalink)
fabler's Avatar
okay.. then go to console and type "ifconfig" command without quotes.. and tell me what is the output..?
fabler is offline
Old 25-02-2009, 07:23 PM   #6 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
chkconf network on
didn't work...
i got error message something like "network not exists"
Old 25-02-2009, 07:37 PM   #7 (permalink)
Juke Box Hero
Don't clearly remember where the network file is located in Ubuntu but try in terminal,
sudo /etc/init.d/network start|stop|restart <try one> [also try network(ing)]
Hitboxx is offline
Old 25-02-2009, 07:39 PM   #8 (permalink)
Pee into the Wind...
shady_inc's Avatar
Switch on the net, boot in Ubuntu and type interminal:
sudo dhcpcd eth0
This will ask for user password enter it and dhcp will lease an IP address.If not post what it says here.
Also post the output of:
ifconfig
Life is as complicated as you say it is.
shady_inc is offline
Old 25-02-2009, 09:02 PM   #9 (permalink)
Default Re: Help needed with ethernet connection
^^well that is supposed to be "0" and no "o" AFAIK !
Faun is offline
Old 25-02-2009, 09:37 PM   #10 (permalink)
shady_inc's Avatar
Whooops..My bad.!Fixed.
Old 28-02-2009, 07:06 AM   #11 (permalink)
techspalace
talktorishav's Avatar
or
dhclient <tab> <tab>
and post your output.
techspalace.blogspot.com - not only ubuntu blog
talktorishav is offline
Old 28-02-2009, 02:08 PM   #12 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
Red face Re: Hwlp needed with ethernet connection
Thanks it worked.........
Old 02-03-2009, 05:27 PM   #13 (permalink)
>>>>>Monkey Power<<<<<
shivkumar's Avatar
Today I update my system. Now internet connection is not starting by itself. Network Manager Applet is displaying message "Network Manager is not running".
I am able to connect to internet by issuing command "sudo dhclient".
help needed...my net connection seems too slow windchimes Mobiles and Tablets 3 16-08-2007 08:07 PM
Broadband connection needed vutonium Broadband and DTH 4 12-04-2006 10:37 AM
HELP NEEDED FOR DIAL UP CONNECTION mandar5 QnA (read only) 3 13-10-2005 06:37 PM
sharing dataone internet connection over ethernet trigger Broadband and DTH 5 26-09-2005 01:19 AM
