Old 20-02-2009, 02:51 PM   #1 (permalink)
Default Problem in Fedora 10
Hello friends i am facing one problem in fedora 10. I have downloaded fedora 10 iso image from its official site. During installation my system hangs. so i have to reformat linux partition and also have to reinstall fedora 10. Now also after running for 10-15 minutes or even in 2 min my system hangs in fedora 10. I have also tried live gnome cd of fedora but no use. But my windows xp runs smoothly also earlier before installing fedora 10 i was using fedora 9 which also runs smoothly please tell me how can i solve this problem of system hanging in fedora. also if there are updates please tell me url of that update which can solve this problem.
abhijangda is offline
Old 20-02-2009, 03:02 PM   #2 (permalink)
Married!
Rahim's Avatar
Default Re: Problem in Fedora 10
Have you created a swap partition? or it might be some drivers problem for your video card.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 20-02-2009, 04:48 PM   #3 (permalink)
a.k.a VipER
Ecstasy's Avatar
Try different mirror and try downloading it again. If the problem is still there then like a_rahim said it must be some video card conflict. Best i would suggest you to go to Fedora forums and post a thread there and you will get the best solution out there.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 20-02-2009, 05:01 PM   #4 (permalink)
i have created swap partition it may be will be problem with my graphics card
Old 20-02-2009, 08:46 PM   #5 (permalink)
May the Force be with you
anurag_bhd's Avatar
a_rahim is right, try installing the latest drivers for your graphics solution. If even that doesn't work, check if the partition you have installed Fedora on is free of errors. HD bad sectors could be a problem.
Impossibilities recede when experience advances
anuragbhandari.com
anurag_bhd is offline
Old 21-02-2009, 03:59 PM   #6 (permalink)
when i downloaded and install ati driver(xpress 200) downloaded from ati site for my video card then i configure driver but after restart there comes a blank screen.
please provide any other solution also there are no bad sectors i have checked through chkdsk command in Win XP
Old 21-02-2009, 04:11 PM   #7 (permalink)
Married!
Rahim's Avatar
^You cant chkdsk ext3 partitions which linux uses. Use GParted Live CD to check the partitions.
Rahim is offline
Old 21-02-2009, 05:39 PM   #8 (permalink)
i have checked that partition through chkdsk by first deleting it and then formatting it in NTFS. I have also checked swap partition but there was no problem. I installed fedora 9 which runs smoothly for some time then i upgrade it to fedora 10. but the problem persists.
Old 22-02-2009, 11:50 PM   #9 (permalink)
hello friends my previous problem related graphics has been solved by just doing
yum install xorg-x11-drv-ati to update ati drivers from 6.9.0-54 to 6.10.
but new problem about sound arises(which also during previous prob.) whenever i play music and move and window or do any thing else the sound cracks. i have updated alsa drivers but this happens even now. any solution please.
Old 23-02-2009, 07:52 AM   #10 (permalink)
anurag_bhd's Avatar
Try changing the sound codecs from Xine to gstreamer in the Phenon setting, if you are using KDE 4.
anuragbhandari.com
Old 23-02-2009, 11:50 AM   #11 (permalink)
i m using gnome 2.2 (i think this version is in fedora 10, i mean defualt version of gnome).i m using alsa drivers for my realtek alc883 onboard sound card. my graphics card is ati xpress 200
Old 23-02-2009, 12:54 PM   #12 (permalink)
BSD init pwns System V
hellknight's Avatar
have you installed gstreamer-ugly codecs and stuff.. if not.. then please install it and tell me the result
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 23-02-2009, 03:52 PM   #13 (permalink)
there's no package gstreamer-ugly available in any repositories if u r talking about gstreamer-plugins-ugly containing codecs then i have installed it earlier. if u r talking about any other package then let me know.
Old 25-02-2009, 01:23 PM   #14 (permalink)
Always confused
vamsi360's Avatar
Smile Re: Problem in Fedora 10
install mplayer from source by compiling it and see.
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline
Old 25-02-2009, 01:34 PM   #15 (permalink)
damnbadman666
damngoodman999's Avatar
Try the swap partition by giving the 2X the size of RAM , and also make sure that u made at least 5 to 10GB for the software raid , fedora core 10 is data redundancy so raid is neither or nor
Try this , if the problem pursued then we can see !
damngoodman999 is offline
Old 01-03-2009, 03:47 PM   #16 (permalink)
i have tried mplayer but no use of it.
Fedora problem!! rahul_u_know_me Software Q&A 1 14-05-2008 09:10 AM
fedora 8 problem.... coollinux Open Source 4 05-03-2008 01:04 AM
Fedora Problem saurabh.sauron Open Source 3 20-09-2007 02:41 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by soumya
- by reddick
