Old 12-02-2009, 05:26 PM   #1 (permalink)
a.k.a VipER
Ecstasy's Avatar
Lightbulb Installing Fedora 10.. need guidance
Hey,
Finally after getting bored with Win XP i decided to go with Fed 10. What i need from you guys is your guidance and tips on how to go about it, firstly installing.
So here are some facts ----> I got 2 HDD and in 1 HDD there are 2 partitions so 'C' drive contains Win XP and in my other HDD there are 3 partitions which contains movies, mp3's, games, etc, etc.
I do not want to uninstall Win XP and i was thinking of having both XP and Fed both.
So how do i proceed with installing Fed 10? Please help.
Thanks in advance and Best Regards.
Originally Posted by shayanthebest View Post
I want to buy a new computer which can play 2-3 year old games at good resolutions. My budget is 5 to 6 lakhs. Please help
Ecstasy is offline
Old 18-02-2009, 01:06 AM   #2 (permalink)
mekalodu
iinfi's Avatar
Default Re: Installing Fed 10.. need guidance
you can dual boot xp and fedora
if possible get some 10GB free for fedora on any HDD. its better if it is a complete drive like d: e: or something
goto windows disk manager and delete that logical volume. this is will make it a raw partition and you will see it as a free partition while installing Linux.
then insert the fedora DVD n reboot .
keep the cd as first boot device.
you can skip the CD check and proceed with the installation till you reach the partition section (custom installtion.
here you can keep around
8G /
1.5G swap
400M /tmp
100M /boot
thats the bare minimum i feel
the next step is critical. you need to select grub as the default boot loader.
and you will see two options out there.
FEDORA
OTHER
check the Os which you want to be loaded by default. Keep the default packages as is and proceed and complete the installation.
well does this crude howto help?
iinfi is offline
Old 18-02-2009, 04:04 PM   #3 (permalink)
a.k.a VipER
Ecstasy's Avatar
Well i installed Fed 10 couple of days back by myself and screwed up badly. My C: partition is gone along with XP. I tried getting it back with the help of Fedora forums and some guys from DF but in vain.
Ecstasy is offline
Old 18-02-2009, 08:50 PM   #4 (permalink)
meh
Phantom Lancer's Avatar
You should be careful when partitioning
Next time
Just empty the contents of one of the drive into your other , then try installing F10 in one of the partition that you choose to .... you may go wrong a couple a times initially .... But 'Practice makes perfect'
Phantom Lancer is offline
Old 18-02-2009, 09:07 PM   #5 (permalink)
Married!
Rahim's Avatar
Never use "Guided" partition options. Manual/Custom is the way to go.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Career Guidance damnthenet QnA (read only) 74 20-05-2009 03:09 PM
NEED: Career Guidance shashank_re Chit-Chat 7 23-01-2008 06:21 PM
CRT Vs LCD- need guidance mobileman Hardware Q&A 3 03-07-2007 09:02 AM
A little bit of Guidance!! Dilip Mallya QnA (read only) 4 29-05-2007 04:41 PM
- by soumya
- by reddick
