Old 31-01-2009, 11:11 PM   #1 (permalink)
Dark Star's Avatar
Default Ubuntu Installed help needed
Hi
I finally installed ubuntu and thinking of settling on it Have few queries..
1. I don't have my monitor resolution set up correctly... I installed latest ATI 9.1 from ATI Site created deb and installed..
Now what I initialize it from Accessories it says
Here is my Xorg.conf
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# Note that some configuration settings that could be done previously
# in this file, now are automatically configured by the server and settings
# here are ignored.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Device"
    Identifier    "Configured Video Device"
EndSection
Section "Monitor"
    Identifier    "Configured Monitor"
EndSection
Section "Screen"
    Identifier    "Default Screen"
    Monitor        "Configured Monitor"
    Device        "Configured Video Device"
EndSection
Rest is fine .. All problem is with resolution..
WIll post on further issue..
Do help please )
Regards
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 01-02-2009, 06:00 AM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Ubuntu Installed help needed
No experience with ATi, but your Xorg looks empty !
See this thread, last post on that page
http://ubuntuforums.org/showthread.p...ati+driver+deb
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 01-02-2009, 07:46 AM   #3 (permalink)
Dark Star's Avatar
Also why I have to manualy mount my XFS and ReiserFS partitions everytime / WHy don't they get mounted automatically
Ok resolution get fixed I installed everything correctly and forgot to activate it through restricted driver manager
Now the problem is how to auto. mount my Ext3, XFS and Reiser FS partition at every boot..
Old 01-02-2009, 10:09 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Add the entries to /etc/fstab.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-02-2009, 07:28 PM   #5 (permalink)
Dark Star's Avatar
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
# /dev/sda1
UUID=47173b0e-56ae-4703-a93a-980e45125a13 /               ext3    relatime,errors=remount-ro 0       1
# /dev/sda2
UUID=58cadce3-ae27-4a7c-91ab-166312e3090b none            swap    sw              0       0
/dev/scd0       /media/cdrom0   udf,iso9660 user,noauto,exec,utf8 0       0
Added some changes in authorization lets see if it works..
Old 01-02-2009, 09:31 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
^^^ Where are the entries for those partitions? I don't see them.
infra_red_dude is offline
Old 01-02-2009, 10:01 PM   #7 (permalink)
Dark Star's Avatar
How do I add them.. I don't know abt fstab options though Its the entry when I mount the partitions...
Old 01-02-2009, 10:13 PM   #8 (permalink)
^^lol
http://www.google.co.in/search?q=aut...ient=firefox-a
Faun is offline
Old 02-02-2009, 08:14 AM   #9 (permalink)
Dark Star's Avatar
^er...Thats for NTFS ? but I don't have any NTFS.. Also I know the sol-n for NTFS. But XFS adn reiserfs and ext didn't mount at boot..
UUID ?
Old 02-02-2009, 08:25 AM   #10 (permalink)
^^ how are xfs and reiserfs different ? They follow same steps
http://ubuntuforums.org/showthread.php?t=951844
http://t.webofgoo.com/2008/03/11/aut...uid-in-ubuntu/
UUID is like a permanent identification of partitions, so its better to mount by using UUID. If you mount by sdX or hdX then changing HDD order in bios will screw up for good.
Faun is offline
Old 02-02-2009, 08:37 AM   #11 (permalink)
Dark Star's Avatar
SOrry.. Didn't knew the blkid command Will add them , I was unsure how to get exact UUID for a partition
shashwat@shashwat-desktop:~$ blkid
/dev/sda1: UUID="47173b0e-56ae-4703-a93a-980e45125a13" TYPE="ext3"
/dev/sda2: UUID="58cadce3-ae27-4a7c-91ab-166312e3090b" TYPE="swap"
/dev/sda3: UUID="94a7c6be-0dac-4d4a-8c44-0059926b9791" TYPE="reiserfs"
/dev/sda5: UUID="94ed6290-b65a-4a71-9187-83378d90522f" TYPE="xfs"
/dev/sda6: UUID="8ff8e640-de64-4bfc-a6a5-137048a6e6f6" TYPE="xfs"
/dev/sda7: UUID="d049ccf6-5690-4b32-9a17-1d23e2436334" TYPE="reiserfs"
/dev/loop0: TYPE="squashfs"
Edited Fstab
# /dev/sda1
# /dev/sda2
#/media/sda3
UUID=94a7c6be-0dac-4d4a-8c44-0059926b9791 /media/sda3     reiserfs defaults 0 0
#/dev/sda5
UUID=94ed6290-b65a-4a71-9187-83378d90522f /media/sda5  xfs defaults 0 0
#/dev/sda6
UUID=8ff8e640-de64-4bfc-a6a5-137048a6e6f6  xfs defaults 0 0
#/dev/sda7
UUID=d049ccf6-5690-4b32-9a17-1d23e2436334 /media/sda7 reiserfs defaults 0 0
Is it right /?
Old 02-02-2009, 08:55 AM   #12 (permalink)
mount point missing for
And yeah for each mount point run the chown command.
sudo chown -R <username> /media/<mountpoint>
e.g.
sudo chown -R shashwat /media/sda3
Faun is offline
Old 02-02-2009, 09:01 AM   #13 (permalink)
Commander in Chief
I hope he did not restart after those changes. It would have spelled doom?
Harsh J
www.harshj.com
Old 02-02-2009, 09:08 AM   #14 (permalink)
Dark Star's Avatar
Yea I just did restart // I couldn't mount my partitions and one is missing :S
shashwat@shashwat-desktop:~$ sudo chown -R shashwat /media/sda3
[sudo] password for shashwat:
chown: cannot access `/media/sda3': No such file or directory
# /dev/sda1
# /dev/sda2
#/media/sda3
#/dev/sda5
#/dev/sda6
UUID=8ff8e640-de64-4bfc-a6a5-137048a6e6f6  /media/sda6 xfs defaults 0 0
#/dev/sda7
So should I remove these entries reboot and re-enter ? and I got all my partitions .. just can't mount them..
Old 02-02-2009, 09:25 AM   #15 (permalink)
have you created mount points or not
e.g.
sudo mkdir /media/sda3
do same for other mountpoints too
There is no need to reboot. You can use this command to mount partitions whose entry is made in fstab
sudo mount -a
and unmount too
sudo umount -a
Faun is offline
Old 02-02-2009, 09:30 AM   #16 (permalink)
Dark Star's Avatar
Thanks Everything worked perfectly. Now is it necessary to use chown now ?
Now I will never have problem with partitions Thansk t159
Old 02-02-2009, 09:49 AM   #17 (permalink)
Chown was needed only once, as when you created those folders (sda3 etc), they were created under super user account (remember you used sudo).
So to be able to write in them you need to own their ownership as normal user (shashwat etc).
You just did a chown to own them to a particular user.
Faun is offline
Old 02-02-2009, 10:47 AM   #18 (permalink)
Commander in Chief
chown - Change ownership. You're the owner now.
Harsh J
www.harshj.com
Old 02-02-2009, 11:30 AM   #19 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Grrrrrrrrrrr (Trying TO Hijack Thread)
Guyz I'm a Noob & Trying to figure out what you guyz did
I hate this damn editing of files :X
I hate terminal :X
I hate anything without GUI
This is the first & last reason I'm still using Windows as Dual Boot
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 02-02-2009, 12:35 PM   #20 (permalink)
Commander in Chief
Install PySDM, its a GUI tool for that purpose.
sudo apt-get install pysdm
Harsh J
www.harshj.com
Old 02-02-2009, 04:14 PM   #21 (permalink)
I hate terminal :X
I hate life I hate humans I hate anything that can type
Faun is offline
Old 02-02-2009, 07:20 PM   #22 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Good thread. Learnt a lot.
@Dark Star:
Can you write in that partition?
I couldn't. I had to further change the group in order to have write access in my ext3 partition.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 02-02-2009, 07:27 PM   #23 (permalink)
^^u could have used
chown -R <username>:<groupname> <mountpoint_path>
e.g.
chown -R noface:noface /media/dld
thanks will add to the tutorial
Faun is offline
Old 02-02-2009, 07:38 PM   #24 (permalink)
Dark Star's Avatar
Yea everything working perfectly.. To change permission .. Just open nautilus in Root mode and right click on the partitions and select properties under permission change the permission..
That should do :_)
Installed INTREPId Ubuntu 8.10 now what ??? esumitkumar Open Source 8 26-11-2008 03:30 PM
Installed Ubuntu.Now What???? thewisecrab Open Source 68 02-10-2008 08:10 PM
How to install ubuntu 7.10 over already installed 7.04 saurabh kakkar Open Source 9 03-11-2007 07:49 PM
installed ubuntu 7.04, now what... blackleopard92 Open Source 13 10-06-2007 08:58 PM
UBuntu 5.1 installed:need Drivers gary4gar Open Source 30 16-06-2006 02:36 PM
- by soumya
- by reddick
