Old 28-01-2009, 09:21 PM   #1 (permalink)
Smile BSNL EVDO Data Card in Opensuse 11.1
Hi Everyone,
Can anyone help me out! I want to use my BSNL EVDO Data Card on my Opensuse 11.1 machine.
Thanks in advance
Abhishek
abhishek98 is offline
Old 28-01-2009, 11:24 PM   #2 (permalink)
BSD init pwns System V
hellknight's Avatar
Default Re: BSNL EVDO Data Card in Opensuse 11.1
Follow these steps.. i think that your modem may get detected
1. Open Yast
2. Then click on Network devices in the left pane.
3. Click on Modem in the right side.
Yast should autodetect your modem... if it does.. then just enter your username, password and the dialing number.. if it doesn't then please post the results here..
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 09-02-2009, 01:47 PM   #3 (permalink)
Fresh Stock Since 2005
you can optionally install wvdial and then after connecting your modem to the computer, open up the terminal and
sudo wvdialconf
and make sure your modem is detected..
now open up your /etc/wvdial.conf using vi as root
sudo vi /etv/wvdial.conf
enter your details and then save..close vi and
sudo wvdial
This should connect yo to the internet..
can anyone suggest me a graphical bandwidth monitor for such connections..
http://www.khattam.info
khattam_ is offline
Old 15-04-2009, 08:44 PM   #4 (permalink)
Hi all,
I connected the EVDO card but there is no item like ttyUSB under /dev. There are items like tty0 to tty25. Because of this am unable to edit wvdial.conf file, since it has the Device field as /dev/modem. What could be wrong? please help.
Also, Yast says that there are no modems connected to your machine. Am using a Lenovo Y3000 series laptop with gnome. I tried even on KDE, but to no avail.
Thanks,
Vallish
vallish_k is offline
Old 21-04-2009, 09:13 AM   #5 (permalink)
^post the o/p of
wvdialconf
khattam_ is offline
Old 21-04-2009, 01:00 PM   #6 (permalink)
Open the terminal as root/sudo
type
#lsusb
you may get output like this .
Bus 002 Device 027: ID 05c6:3197 Qualcomm, Inc.
Bus 002Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Above entries' Bus 002 Device 027: ID 05c6:3197 Qualcomm, Inc. is the new device which shown in my laptop ZTE modems are from Qualcomm chip. so watch out
red colour may be any of the number remember it.
type thihs command
# modprobe usbserial vendor=0x05c6 product=0x3197
Terminal simply again give you the command shell
Now open nano/vi
ensure that the module gets loaded to your kernel each time you restart your system by adding the following line into /etc/modules,
usbserial vendor=0×05c6 product=0×3197
again type ,
#lsusb -v | grep Qualcomm
You will get this out put,
Bus 004 Device 022: ID 05c6:3197 Qualcomm, Inc.
idVendor 0×05c6 Qualcomm, Inc.
Now its time for us to create the dialup profile. Its so simple with “wvdialconf” command.
#wvdialconf /etc/wvdial.conf
In reality I did't use the wvdial.conf.
I open kppp simply configured in the GUI interface by giving required details.. while dedecting the modem watch for 'ttyUSB0' point this. Inthe user name give yourBSNL user name and password is BSNL password ( this is your phonenumber).
I find it very useful using the kppp instead of wvdial.. however kppp is not working for me in kde4.0 versions of all distro presently I am using Sidux
vaithy is offline
Old 30-09-2009, 05:41 PM   #7 (permalink)
Smile Re: BSNL EVDO Data Card in Opensuse 11.1
thank you everyone for your help!!
Posted again:
Old 02-10-2009, 12:04 AM   #8 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
I recall seeing this somewhere before so I'm posting that thread in here as well just in case it has something more to add to this .
BSNL EVDO card driver installtion in linux
FilledVoid is offline
What is BSNL EVDO? ajaybc Broadband and DTH 12 27-12-2008 03:20 PM
BSNI EVDO data card? viruses Reviews 3 13-12-2008 04:00 PM
Don't go for BSNL EVDO!!BSNL cheating is some areas. Harvik780 Chit-Chat 2 09-10-2008 12:02 AM
BSNL EVDO CLUB - My New Website! Gigacore Chit-Chat 21 10-04-2008 10:05 PM
- by soumya
- by reddick
