Re: Help-Using Linux on nVidia based MB.
Have you installed the latest drivers?
If so, follow the below method..
In the terminal, type
sudo nvidia-settings
and navigate to 'X Server Display Configuration'.
On the right side, choose your desired resolution and 'apply' it.
Now, click on 'Save to X Configuration File'. It says that you are merging the modification with '/etc/X11/xorg.conf'. Save it.
I always love learning..
But i hate reading..
