Old 27-12-2008, 03:24 PM   #1 (permalink)
TheSaint
NucleusKore's Avatar
Default Formatting a usb pen in fat32 using mkdosfs
After unmounting the pendrive, and using fdisk to set the partition as W95 FAT32, I used the following command
sudo mkdosfs -F 32 /dev/sdb1
Now everything was successful, but when I try to paste files as user I cannot because the owner of the filesystem is root (I had to be root to fdisk and mkdosfs).
So how do I solve this problem?
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 27-12-2008, 04:36 PM   #2 (permalink)
Linux User
ghost at rest's Avatar
Default Re: Formatting a usb pen in fat32 using mkdosfs
Re-Mount stick and set umask value to zero. Let say, /media/sdb1 is mount point ( folder ). In case it doesn't exist, create it.
sudo umount /dev/sdb1
sudo mount -vfat /dev/sdb1 /media/sdb1 -o defaults,umask=0
Regular user will have full privileges.
ghost at rest is online now
Old 28-12-2008, 09:03 AM   #3 (permalink)
TheSaint
Thank you for your reply, will await other replies too. This is a manual method. I am ok with it, but not if I teach newcomers.
Please have a look at this thread also
http://ubuntuforums.org/showthread.php?t=1022712
Old 28-12-2008, 09:53 AM   #4 (permalink)
Linux User
Easiest but a risky way is, press Alt+F2 and type this
gksu nautilus
It will open Nautilus with root privileges. You will have full access to every file/folder. Risky, because you will root user and it not good to have root privileges in GUI.
Old 30-12-2008, 02:14 PM   #5 (permalink)
I usually use mkfs.vfat to format usb on linux. Is this different from the method discussed here ?
vinayasurya is offline
Old 30-12-2008, 09:28 PM   #6 (permalink)
TheSaint
Maybe the same?
http://linux.about.com/od/embedded/l...l8_mkfsvfa.htm
Old 30-12-2008, 09:48 PM   #7 (permalink)
blondie's Avatar
Try adding the user to group haldaemon, since the mounting and things are controlled by hal.
blondie is offline
Old 30-12-2008, 11:20 PM   #8 (permalink)
Linux User
mkfs.vfat and mkdosfs -F 32 do the same job. Both commands format partition in FAT32 filesystem in similar way.
FAT32 partiton Ashok Verma QnA (read only) 6 20-06-2008 11:02 PM
FAT32 from XP Vivek788 Software Q&A 10 24-09-2007 06:36 AM
FAT32 to NTFS bhoolkumehul QnA (read only) 3 12-10-2006 10:52 AM
FAT32 to NTFS Raaza QnA (read only) 9 26-09-2006 01:01 AM
Ntfs Or FAT32, Why? khattam_ QnA (read only) 20 28-03-2005 10:28 AM
- by soumya
- by reddick
