Old 20-12-2008, 02:27 PM   #1 (permalink)
TheSaint
NucleusKore's Avatar
Default Installing dropbox on OpenSUSE 32-bit
Hi
I would like to report that the FC9 rpm works great. NO need to compile from source (actually that did not work for me).
First open YaST and install the GNOME desktop environment if you are a KDE user. (I tried making do with just installing nautilus and dependencies but that doesn't work !)
After this logout and change your session to GNOME and login.
Install nautilus-dropbox-0.5.0-1.fc9.i386.rpm from http://www.getdropbox.com/
Logout and then login (GNOME)
Drop box will launch in the system tray and you'll get a popup notification click on it and it will start downloading the client. After it installs you'll have to logout/login (GNOME) again, and then the dropbox registration/setup wizard opens. Go through it and take care to select that you'd want to manually locate the dropbox folder, else the linux default is in your home folder /home/yourusername
After setup is over, logout.
Now you can login with a KDE session.
Press Alt and F2
type nautilus and press ENTER
Nautilus will open and dropbox will be launched in the system tray. Once this is done you can close nautilus; dropbox will remain running in the system tray.
Note: I got a segmentation fault error when trying to open nautilus, for a while, in KDE. This resolved after a reboot?!
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 20-12-2008, 02:42 PM   #2 (permalink)
Juke Box Hero
Default Re: Installing dropbox on OpenSUSE 32-bit
Apparently here's a little tidbit to run it on KDE without Nautilus(GNOME) given by hullap on IRC.
http://antrix.net/journal/techtalk/dropbox_kde.html
Hitboxx is offline
Old 20-12-2008, 03:02 PM   #3 (permalink)
TheSaint
It goes
"Download the closed source Dropbox Linux client from http://www.getdropbox.com/download?plat=lnx.x86 (x86_64 for 64 bit)"
That link however does not work. And it's closed source?
Old 20-12-2008, 03:11 PM   #4 (permalink)
Juke Box Hero
The idea is to download Dropbox client, that's all. If that doesn't work you can search getdropbox.com for the client download I guess.
As for the closed thing, read http://blog.hacker.dk/2008/10/dropbo...t-open-source/
Hitboxx is offline
Old 20-12-2008, 08:45 PM   #5 (permalink)
TheSaint
Thanks for the information.
lost HDD partition after installing openSUSE 11.0 himadri_sm Software Q&A 3 28-10-2008 06:35 AM
Installing openSUSE 10.2 help... vivektheone Open Source 2 02-03-2007 06:35 PM
CDs for OpenSUSE nishant_nms Open Source 3 18-12-2005 01:42 AM
- by soumya
- by reddick
