Old 19-12-2008, 12:22 PM   #1 (permalink)
Always confused
vamsi360's Avatar
Smile Arch made easy!
Installing arch is made simple by softpedia. It will make it simple but you dont enjoy your frustration installing arch.
I too have spent 5 hours to install window managers,X.....but the wiki is really good.All the time is spent to read it carefully.First I was shocked not to see the GUI in linux, misleaded it is a server but after refering to Distrowatch learnt that it is SIMPLE Linux. Is it really simple?
It has X already added in the ISO
Anyway EASIEST Arch :::
Tutorial-------->http://news.softpedia.com/news/How-t...ux-59239.shtml
Link to distro ISO----->http://linux.softpedia.com/get/Syste...inux-864.shtml
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline
Old 19-12-2008, 12:39 PM   #2 (permalink)
Default Re: Arch made easy!
5 hours for installing window manager
It takes less than 2-3 commands to get GUI. Yeah the net speed decides the completion of download.
Faun is offline
Old 19-12-2008, 01:29 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
yeh... you installed all gnome/kde ? :O
I think x-window manager can be installed less than half hour.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 19-12-2008, 03:45 PM   #4 (permalink)
Always confused
vamsi360's Avatar
Post Re: Arch made easy!
I have read that KDE installation takes a day. I have not yet installed a desktop environment but X and window managers installation were installed successfully ( that too with great difficulty until in my college they teached unix commands.
But one thing using net as resource and experting CLI can make things a bit easy.
Vamsi Subhash
vamsi360 is offline
Old 19-12-2008, 04:46 PM   #5 (permalink)
Nope it takes less than 30 minutes if you 2 mbps connection.
And yeah Arch requires the user to know common linux lingo.
Faun is offline
Old 23-12-2008, 01:42 PM   #6 (permalink)
Always confused
vamsi360's Avatar
I have a 128KBPS cable connection at home. Anyway I have no time at present to look back at arch. May be I will try again in June after my 4th sem. I will then install KDE 4.x and post my desktop.
Vamsi Subhash
vamsi360 is offline
Old 23-12-2008, 01:48 PM   #7 (permalink)
Originally Posted by vamsi360 View Post
I have a 128MBPS cable connection at home. Anyway I have no time at present to look back at arch. May be I will try again in June after my 4th sem. I will then install KDE 4.x and post my desktop.
128MBPS?
ThinkFree is offline
Old 24-12-2008, 01:23 PM   #8 (permalink)
Always confused
vamsi360's Avatar
128KBPS dude I have corrected it
Vamsi Subhash
vamsi360 is offline
winamp presets in xmms player... made easy ;-) vish786 Open Source 4 15-06-2007 08:33 PM
Locking yourself into OfficeOpenXML and Office 2007 made easy eddie Technology News 5 16-05-2007 02:10 AM
Creating a Php-Nuke Portal (Made Easy) cyberia.in Tutorials 9 06-07-2005 05:09 PM
- by soumya
- by reddick
