Old 12-12-2008, 01:32 PM   #1 (permalink)
maddy_in65's Avatar
Default Ubuntu 8.10 Installation Problem
I have Dell 1525 laptop and it has 2 partition C 120GB and D 40GB with vista installed on C. When i tried to install Ubuntu, it shows 100% blank Disk and it wasnt detect C and D drive, i tried to partition it during installation by selecting manual partition. I created 40GB for ubuntu and click on forward, it shows "No root file system found". I am unable to install it. If the installer shows 100% blank disk does it mean it would wipe out C and D. How should i select Root System. Please help me.
maddy_in65 is offline
Old 12-12-2008, 02:31 PM   #2 (permalink)
Call me Sumit
esumitkumar's Avatar
Default Re: Ubuntu 8.10 Installation Problem
Install partition manager on windows ....Delete ur last partition D ...Now boot from Ubuntu CD ..and select that unallocated partition as ur root drive by putting a / ..After that u will have dual boot system
But a caution DO NOT INSTALL UBUNTU if u want ur HD to survive ..Dload Fedora 10 and install that
Read here Hard disk life cycle issues of Laptops running Linux
esumitkumar is offline
Old 12-12-2008, 03:19 PM   #3 (permalink)
When you made the new partition , did you select / as the mount point from the drop down menu?
ThinkFree is offline
Old 12-12-2008, 04:32 PM   #4 (permalink)
Always confused
vamsi360's Avatar
Post Re: Ubuntu 8.10 Installation Problem
Follow this:
1.Select manual partitioning in setup
2.Now delete the 40GB drive
3.If your RAM is 2GB create approx. 4GB of swap partition
4.Next create an ext3 partition with mount point "/"(root) of atleast 10GB
5.If you want use the remaining space and create a new partition ext3 with mount point /home (i recommend it as your data may be large)
Thats it!
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline
Old 12-12-2008, 09:23 PM   #5 (permalink)
maddy_in65's Avatar
For creating Swap partition do i need to create another unallocated 4GB partition as my ram is 2GB.
Old 12-12-2008, 09:26 PM   #6 (permalink)
TheSaint
NucleusKore's Avatar
Don't frighten him about Ubuntu
GO here
http://ata.wiki.kernel.org/index.php...ds_under_Linux
and see if your hard disk is listed. You can get your hard disk model number from the device manager in windows. If it matches then stay away from Ubuntu.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 12-12-2008, 09:35 PM   #7 (permalink)
Always confused
vamsi360's Avatar
Dude you and I both are in trouble. I too have an Inspiron 1525 with linux and is listed in the link given by NucleusKore. So it is nice to be away. I think fedora has no problems try that...
Vamsi Subhash
vamsi360 is offline
Old 12-12-2008, 10:02 PM   #8 (permalink)
maddy_in65's Avatar
Ok but is there any problem with Dell on installation of Ubuntu, i had another HP laptop and i am using ubuntu 8.04 with charm.
Old 13-12-2008, 08:48 AM   #9 (permalink)
Call me Sumit
GO here
Better to stay away from Ubuntu till bug is solved
Old 13-12-2008, 11:30 AM   #10 (permalink)
Always confused
vamsi360's Avatar
All versions of Ubuntu work on 1525 inspiron, even Dell ships Ubuntu with Inspiron 1525 in some countries and even has a wiki page and a Dell Ubuntu exclusive distro.
Dell states no problem with this bug but better to be sensible with this for some time.
Vamsi Subhash
vamsi360 is offline
Old 13-12-2008, 12:04 PM   #11 (permalink)
Even 2GB will be enough. If you need to increase size for swap, you can create a file on another partition later and the performance will be same as that of separate swap partition provided you are using latest version of kernel.
Open the link provided by NucleusCore, your doubt will be cleared.
Old 13-12-2008, 01:24 PM   #12 (permalink)
maddy_in65's Avatar
Thanks for the help NucleusKore
Ubuntu 7.10 Installation problem chandru_skc Open Source 2 26-12-2007 04:49 PM
ubuntu installation problem anarchist Open Source 1 01-04-2007 10:57 PM
Ubuntu Installation Problem soham Open Source 6 01-02-2007 08:37 PM
Ubuntu 6.06 giving installation problem Dink2cool Open Source 7 22-07-2006 10:50 PM
Ubuntu 6.06 Installation Problem ! Zeeshan Quireshi Open Source 7 08-07-2006 06:10 PM
