Old 07-12-2008, 07:24 PM   #1 (permalink)
A human, I use Ubuntu
pradeepbp's Avatar
Default Java SDK installation
I want to install Java SDK on ubuntu hardy. I downloaded the bin file from sun's site and extracted the same by running it. Now how would I make ubuntu to choose this as my default Java SDK?
pradeepbp is offline
Old 07-12-2008, 08:46 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Java SDK installation
Follow this. Though its for 1.5, it should do the task for 1.6 too (Use tab-auto complete).
Or simply, sudo apt-get install sun-java6-jdk, if you have internet access.
Harsh J
www.harshj.com
QwertyManiac is offline
Java programming..how can I distribute java program....? Manojap Programming 5 16-05-2009 02:46 PM
What is more powerfule Core Java or Java ? avadhesh QnA (read only) 4 06-05-2008 04:55 PM
jAVA bizzare_blue QnA (read only) 4 30-01-2005 10:53 AM
java installation johny QnA (read only) 2 08-12-2004 11:23 AM
