| Forum |
#1 (permalink) |
The Thread Killer >:)
Want to make this world a better place? Then, start seeding and don't be just a leecher |
#2 (permalink) |
life is short..be happy
i also face the same problem
the clock set +5:30 than current time i have a triple boot-UBUNTU+MANDRIVA+XP sometimes goes wrong in XP as well as Linux Any help ppl
Digit Tutorials Index | Digit Toolbar | Official I5801 Thread Worried about privacy?use DuckDuckGo! ! |
#3 (permalink) |
Married!
Just change the time in the BIOS to GMT ie make it 5 1/2 hours backward. Ubuntu messes it as it doesnt give an option to choose That Hardware clock is set to Local Time.
Eg: Suppose its 11 AM local time but it would show 4:30 PM in Ubuntu bcoz of +5 hrs 30 minutes,just change the BIOS clock to 5:30 AM. Now all the OS will show correct time.
topdocumentaryfilms.com |
#4 (permalink) |
Isn't there a fix in linux itself?
I had found this before posting, but it hadn't worked out, see if it works out for you gopi http://dreamlinuxforums.org/index.php?topic=1956.0
Want to make this world a better place? Then, start seeding and don't be just a leecher Last edited by phreak0ut; 08-12-2008 at 12:26 AM. Reason: Automerged Doublepost |
#5 (permalink) |
Commander in Chief
I just select my location and it pretty much works right from there. Alternatively, why not use NTP programs and sync with time servers?
Harsh J www.harshj.com |
#6 (permalink) |
@QM-NTP works fine when I'm connected to the net, but sometime I just don't connect to the internet. I'm still facing this problem on Fedora and Dreamlinux. Is this some kind of a bug?
#7 (permalink) |
TheSaint
Your distros have been configured so as to detect the bios time as UTC. You will have to change this option to local time. Methodology varies with the distro.
For Ubuntu read this page (scroll way down) https://help.ubuntu.com/community/UbuntuTime According to them this UTC problem has been solved in Intrepid. OpenSuSE http://en.opensuse.org/YaST/Modules/Date_and_Time
http://www.neville.in http://www.linuxrocks.in "The Future Is Open" Last edited by NucleusKore; 10-12-2008 at 01:12 AM. Reason: Automerged Doublepost |
#8 (permalink) |
@Neville-Thanks a ton for the post. NTP still can't fix the problem
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| CMOS setting wrong | quark | Hardware Q&A | 5 | 13-06-2008 09:51 AM |
| Setting up an internet connection in linux | desmond_315 | Open Source | 12 | 22-12-2006 02:01 AM |
| Setting up ftp,telnet,ssh server on linux?? | mediator | Open Source | 2 | 06-01-2006 11:37 PM |
| Setting up Linux on RAID Disks | pradeep_chauhan | Open Source | 1 | 29-12-2004 07:08 PM |
