Old 24-05-2005, 08:09 PM   #1 (permalink)
Default Virtual memory setting
Is there anyway i can check out the size of virtual memort currenty in use.
Is there any software to check the same.
Also what should be the optimum size of the virtual memory that should be set.
ALIVE HUNTER
Alive_Hunter is offline
Old 24-05-2005, 08:16 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: Virtual memory setting
Originally Posted by Alive_Hunter
Is there anyway i can check out the size of virtual memort currenty in use Is there any software to check the same.
Try this:
$ free
Or this one
$ cat /proc/meminfo
Or otherwise you can add the System Monitor applent in GNOME panel and add memory, swap, network applents
Experts say twice of your RAM... but if you have a large RAM then even this rule can be twisted.
http://web.gnuer.org
GNUrag is offline
Old 24-05-2005, 08:16 PM   #3 (permalink)
Come on dude, u never noticed u allocate a diffrent partetion for virtual memory, (Linux swap)
so hw much u hv allocated is ur VM
and yes if u want to cahek it in use, then let me think, u can do it even without using any command...........
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 24-05-2005, 08:35 PM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
He probably want to know how much of swap space is currently being used which the system is doing some computation. Which will be lower than the total amount of swap installed on his system.
I would like to know how to do that.
GNUrag is offline
Old 25-05-2005, 02:05 AM   #5 (permalink)
please educate me too on your statement.
**** happens
pradeep_chauhan is offline
Old 25-05-2005, 06:52 AM   #6 (permalink)
gauravnawani's Avatar
He is refering to allocation of swap space during the installation process.
And there are few system stats application that shows you the umm. stats... . Like for example 'system Monitor' inf FedoraCore 3 under Gnome desktop.
You can also use 'top' command at terminal for the same.
-gaurav
Blender India forums
http://www.bestfreeforums.com/forums/blenderindia.html
gauravnawani is offline
Old 26-05-2005, 02:07 PM   #7 (permalink)
Yup i got it,
One of my friend showed me hw to check it's swap space in use in GUI mode,
I think i have forgetten the way to do it,
But i think Gaurav is right it was one of the monitoring tool to check it.................
- by reddick
