Old 19-11-2008, 10:09 PM   #1 (permalink)
Dark Star's Avatar
Default Help Merging Unused HDD space
How am I suppose to merge this ?
Please help me
Regards
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 19-11-2008, 10:12 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: Help Merging Unused HDD space
First move sdb5 to the start or the end, then you can merge
Provided both unallocated spaces are on the same hard disk. If not, you will have to use LVM, which will mean loss of data.
kalpik is offline
Old 19-11-2008, 11:17 PM   #3 (permalink)
Dark Star's Avatar
They are on the same HDD As its clear from SS ! How am I suppose to move sdb5?
Old 19-11-2008, 11:23 PM   #4 (permalink)
kalpik's Avatar
Select it, click on the Move button, and then just drag the entire partition
kalpik is offline
Merging 2 partitions gxsaurav QnA (read only) 23 11-12-2007 08:50 PM
Merging SP2 with XP cd ComputerUser Software Q&A 8 14-05-2007 04:51 PM
Unused space on hard drives recovered? quad master Hardware Q&A 2 08-12-2005 11:22 PM
- by reddick
