Old 03-11-2008, 06:51 PM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Default GCC error- help
1. When I compile using GCC, its giving me error 'cannot find stdio.h...other header files.' Its just a simple hello program that I checked. It used to compile the last time I ran.
I checked the directory: /usr/src/linuxheader.../include/asm. There are no stdio.h, stdlib.h header files. What went wrong?
Help please.
http://twitter.com/blueshift155
blueshift is offline
Old 03-11-2008, 07:00 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: GCC error- help
Install the header files.
For example, on Ubuntu, an easy way to get all development libraries is to install the build-essential package (Its even on the CD).
Harsh J
www.harshj.com
QwertyManiac is offline
Old 03-11-2008, 07:15 PM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
Ok.
I checked in Synaptic. It is showing uninstalled...so this will work.
Thanks!
Old 03-11-2008, 07:40 PM   #4 (permalink)
yep 100% guaranteed
Faun is offline
Old 03-11-2008, 07:45 PM   #5 (permalink)
Back!
red_devil's Avatar
@blueshift, me had similar problems.. more on this thread :-
ubuntu - gcc package problem
red_devil is offline
Old 04-11-2008, 12:05 AM   #6 (permalink)
Wise Old Crow
blueshift's Avatar
Thanks. Though I haven't used build-essential, but my problem is solved.
Old 04-11-2008, 03:10 AM   #7 (permalink)
Commander in Chief
build-essential is a meta-package, it installed a lot of stuff for you, you are inadvertently using it.
Harsh J
www.harshj.com
fatal error C1189: #error : WINDOWS.H already included. diyora Programming 3 07-05-2008 02:31 PM
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
- by reddick
