Old 21-05-2005, 08:48 PM   #1 (permalink)
Default Linux ( All flavours ) installation problem
Hello everybody,
I have a serious problem. I recently upgraded my system to p4 on intel 845 with 256MB RAM (266MHz)......
Now no version of Linux is running on my PC. Earlier ( when my pc was P3 based), all versions were running smoothly.
I just installed SUSE 9.1. But at the loading time, the following error is displayed...
INIT: ...... Spawning too fast. Suspended for 5 minutes.
and after 5 minutes same error is displayed.
Please asist/help.
wormhole is offline
Old 22-05-2005, 01:24 AM   #2 (permalink)
Try To Install Mandrake linux
fahad_th is offline
Old 22-05-2005, 11:06 AM   #3 (permalink)
Is there any Live CD of mandrake?? Then I don't have to install it on my hard disk.
wormhole is offline
Old 23-05-2005, 07:37 PM   #4 (permalink)
Hey! I found the problem.
Linux runs ok when i use my onboard agp.
But it fails when i use my geforce 4 440mx se graphics card.
What can i do? pls help. i want to run linux using my geforce 4.
wormhole is offline
Old 23-05-2005, 10:59 PM   #5 (permalink)
well i also got this problem of init "X" respawning too fast in knoppix and its the same stopped for 5 minutes :d
When I typed kdm no response except flickering screens, then i found the path of xserver and typed something like starting with /etc/.../ something.... instead of startx, then i also tried startx, nothing responded.
Solution is required here also
h4xbox is offline
Old 25-05-2005, 03:25 PM   #6 (permalink)
Yeah...there is a live CD version of Mandrake. You can find it either at www.mandriva.com or www.distrowatch.com. It's called Move and you can get it here : http://www.mandriva.com/products/move
Regarding the Knoppix thingy - i really cant help much but here's some info that helped me. Use the following cheat code at boot and it shoudl help
-maxhsync = 60 ...i think that was really all it needed. Also try to boot using the standard VGA mode, -i think thats -knoppixVGA
aaah what the hell...the complete list of cheat codes are at the knoppix website or on the installation CD.
The web is a big, bad place little fly.
Arachnid is offline
Old 31-05-2005, 07:16 PM   #7 (permalink)
This problem is common in intel 845G chipsets using external AGP cards. Will the future versions of linux solve the problem?
wormhole is offline
- by reddick
