Old 01-11-2008, 11:46 AM   #1 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default gzipping root partition: will it work.?
Hi there.!
I have an Arch Linux installed on a 5 GB partition.I plan on buying a new hard disk soon and have only Arch's root partition plus a home partition on it.Will gzipping the current root partition and then gunzipping it on the new hard disk's root partition work, since I really don't wanna reinstall Arch again.
Thanks.
Life is as complicated as you say it is.
shady_inc is offline
Old 01-11-2008, 02:55 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: gzipping root partition: will it work.?
Guess it will work, but also do the necessary changes to the bootloader configuration.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-11-2008, 08:42 PM   #3 (permalink)
shady_inc's Avatar
A bit of reading the man pages tells me that tarring / will be a better option than gzip..Running tar -cvf / will include even my home partition in tar file.How do I ignore the /home partition from being included in the tar file.?
Old 01-11-2008, 08:56 PM   #4 (permalink)
adi007's Avatar
Hmmm... how about creating the images using some live cd or Norton Ghost or Drive Image and then restoring the backup ...?
I think their is a Open source software too but forgot the name
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 01-11-2008, 09:05 PM   #5 (permalink)
Commander in Chief
--exclude=home perhaps?
Tar it via an external source? (Live CD, even Windows?) So that you can mount only / and not /home/ and thus tar worry-free. Do mind the permissions, they have to remain consistent.
Why not gzip? Its just got compression (Lempel Ziv). You anyways would have to extract it via a Live CD or so I guess?
Harsh J
www.harshj.com
Old 01-11-2008, 10:02 PM   #6 (permalink)
shady_inc's Avatar
The good old cp command did the trick.!
I booted in a Knoppix LiveDVD, mounted only my Arch root partition and the would-be root partition and then ran the command :
cp -pidvxR /old_partition/* /new_partition/
The options mean:
p - preserve file permissions, timestamps etc...
i - prompt before overwrite (just in case).
d - To copy symlinks as symlinks rather than the file they point to.
v - to be verbose about the process.
x - To stay on one filesystem.
-R copy recursively.
Works like a charm.Now I can truly say I will NEVER EVER have to re-install Arch Linux again.!
BTW, don't forget to make appropriate changes to /boot/grub/menu.lst and /etc/fstab after copying..
Another BTW: I could have perhaps run to cp command from within Arch, but it was the special directories like /proc and /dev that had me worried.So I chose a liveCD for the task.
Old 01-11-2008, 10:05 PM   #7 (permalink)
time to party
Faun is offline
Old 01-11-2008, 10:20 PM   #8 (permalink)
Commander in Chief
aren't proc and dev supposed to be "mounted"?
Harsh J
www.harshj.com
Work, Work & Work.... u get no raise ! vish786 Chit-Chat 5 14-09-2007 03:49 PM
Root password ra_sriniketan Software Q&A 4 15-11-2005 12:58 PM
root login nishant_nms Open Source 7 13-11-2005 01:40 PM
Root Password godsownman Software Q&A 5 13-07-2005 08:59 AM
How did Anyone Traces the Root ? visvo QnA (read only) 3 06-06-2005 12:15 PM
- by reddick
