Old 28-10-2008, 06:05 PM   #1 (permalink)
Default problem with partitioning in suse
I have openSUSE running on a 20 GB ext partition... I need to resize this and create a new partition of 10 GB out of this 20 GB to install a difft distro of linux.... Can I do it without formatting the drive???
sarincv is offline
Old 28-10-2008, 07:10 PM   #2 (permalink)
Married!
Rahim's Avatar
Default Re: problem with partitioning in suse
^Yes you can!! Find the partitioning tool under YaST.
For all your partitioning needs GParted Live CD is the best. Its easy and very intuitive.
There will be no problem.
Hope you dont go on distro hopping as i have done. Most of them are similar and are not radically different. Popular distros like Ubuntu or its derivatives, openSUSE, Mandriva, Fedora,etc., are all nearly as good as the other. Just pick 2 of them and start learning Linux.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 29-10-2008, 08:49 AM   #3 (permalink)
in the partitioning tool, there is an option to resize but when tried its saying the partition with mountpoint / cannot be resized....
The problem with openSUSE is its very slow.... when I drag and drop the windows, its hanging in between... when scrolling down, the same thing occurs... Does Fedora come with KDE Desktop?
I can do this without losing any data rite????
sarincv is offline
Old 29-10-2008, 03:40 PM   #4 (permalink)
Married!
Rahim's Avatar
You cannot resize a mounted partition. Since "/" root partition is where opernsuse resides, it cannot be un-mounted at the same time.
Use GParted Live CD and you wont face any problem.
Yes Fedora comes with KDE, though the default is GNOME.
Rahim is offline
Old 29-10-2008, 05:10 PM   #5 (permalink)
k... the redhat omega live cd had only GNOME....thats y i asked....
sarincv is offline
Old 29-10-2008, 05:28 PM   #6 (permalink)
Married!
Rahim's Avatar
Fedora DVD contains both KDE and GNOME and you can choose which DE to install. Dont know much of this Omega stuff
Get Fedora 9 KDE Live CD http://fedoraproject.org/get-fedora
Rahim is offline
HP DV6910US HDD Partitioning problem passion_unlimitedd QnA (read only) 1 25-08-2008 12:32 PM
Suse Problem :D Ecko Open Source 5 14-01-2008 06:11 PM
strange problem in partitioning new 320gb harddisk..... tango_cash Hardware Q&A 3 08-01-2008 06:58 PM
Problem with Partitioning HDD tirthasanyal QnA (read only) 4 18-08-2005 12:40 PM
SUSE 9.1 Problem shwetanshu Open Source 11 24-03-2005 07:39 PM
- by reddick
