Old 23-10-2008, 12:54 AM   #1 (permalink)
Default ubuntu 8.04 reinstallation problem
hi m new to ubuntu n my problem is that i had my system with hardy running but problem came when i tried reinstall due a problem in the windows partition. wen i try to reinstall it goes fine up to the manual partition stage but after that wen i click install button it goes back to the partition stage again. i hav tried formatting the whole hard disk but no solution so can u pliz help me in this.
yaikhomba1963 is offline
Old 23-10-2008, 12:15 PM   #2 (permalink)
Blogger
hariharakumar's Avatar
Default Re: ubuntu 8.04 reinstallation problem
make your question even more clear,
Visit my blog at http://geekspage.tk/
Check my blog for updates on Blogging, Social Media, Software.
follow me on Twitter: http://www.twitter.com/hariharakumar
hariharakumar is offline
Old 28-10-2008, 01:11 PM   #3 (permalink)
i use ext3 wit file jounaling but wat my fren said is that he too had the same problem but the matter was solved with ext2 file system. as i have told before that there is no problem till the manually partition of hard disk stage. so after selecting the ext3 with jounaling and trying to install the process goes back again to the hard disk partition stage, and doesnt allow me to go ahead with the installation. i hav tried formatting the whole of the hard disk by reinstalling win XP but the problem still persist. i have not tried with ext2 but i think i sud not b having a problem with ext3. pliz help me out........
Old 28-10-2008, 03:56 PM   #4 (permalink)
Married!
Rahim's Avatar
Have you selected a "root" / and swap partitions and click on "Apply"?
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 03-11-2008, 11:27 AM   #5 (permalink)
yes i have but i dont know where the problem is
Old 14-11-2008, 10:35 AM   #6 (permalink)
Married!
Rahim's Avatar
^Reported
Rahim is offline
Ubuntu Hardy Heron Reinstallation Query techtronic Open Source 11 13-05-2008 05:17 AM
xp reinstallation problems.someone plz help utsav Software Q&A 9 24-08-2007 03:09 PM
XP reinstallation problem Suhas Software Q&A 7 24-08-2007 01:30 PM
IE 6.0 Corrupted, reinstallation also doesn't helps. Mangal Pandey Software Q&A 9 26-02-2007 08:58 PM
Webroot's SpySweeper reinstallation problems rakesh-the gilli Software Q&A 4 27-07-2006 09:34 AM
- by reddick
