Old 21-10-2008, 11:55 PM   #1 (permalink)
Default Software installation problem in fedora 9
hello friends please help me. I installed fedora 9 from digit dvd after 3 to 4 days whenever i install any software by package kit it says that "No network connection avalaible." When i click on more information it says "cannot install offline". this happens even when i am online and then also when software source is specified as the fedora 9 dvd and dvd is also present. So i update my system and install new package kit but even then the same problem persists please help me.
abhijangda is offline
Old 22-10-2008, 04:06 PM   #2 (permalink)
fabler's Avatar
Smile Re: Software installation problem in fedora 9
Hi do the following steps...
1. vi /etc/yum.repos.d/install_media.repo
2. Add following lines in it..
[install_media]
name = install_media
baseurl= file:///mnt
enabled = 1
gpgpcheck = 0
NOTE: file:///mnt is the mount path of your CD/DVD drive..
and you're done.. now try to install softwares via yum from command prompt or you can use software add/remove GUI application of fedora 9.
if you have any further query post here...
fabler is offline
Old 27-10-2008, 04:59 PM   #3 (permalink)
Default Re: Software installation problem in fedora 9
No i was not talking about repository it even occurs when i select the dvd as medium. I have corrected the problem first update your packagekit then restart. Then login as root go to /etc/PackageKit/ u will find a single file there open it with gedit. There you will find two lines "default = yes" and"UseNetworkManager=yes" 2 times change all 4 yes to no. and save restart ur computer and it works it works for me upto now.
fedora 7 installation problem .. ninad_mhatre85 Open Source 3 27-09-2007 10:32 AM
Fedora 7 installation problem sureshkumar Open Source 10 22-09-2007 09:26 PM
Fedora installation problem sureshkumar Software Q&A 1 09-09-2007 02:17 PM
Fedora Core 5 installation through CDs giving problem Dink2cool Open Source 19 25-06-2006 12:07 AM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by reddick
