Old 18-10-2008, 05:02 PM   #1 (permalink)
Unhappy No sound in Mandriva 2009/ Fedora 9/ Omega 10
I have installed Mandriva 2009 One edition.....
System: Dell Studio 1535
Chipset: Intel GM/PM 965
Audio Device: IDT 92HD73C ( as shown in BIOS)
In mandriva, when I entered lspcidrake -v at console, the audio device is shown as snd_hda_intel : 82801H (ICH8)
But when I entered /sbin/chkconfig --list sound & /sbin/chkconfig --list alsa, an error message is shown - "error: no such file or directory"
the file chkconfig does exist in the given path.... Help me
later I tried installing omega 10 and fedor 9.... all of them is having the same problem...
sarincv is offline
Old 19-10-2008, 11:20 AM   #2 (permalink)
Resistance is Futile.
coolpcguy's Avatar
Default Re: No sound in Mandriva 2009/ Fedora 9/ Omega 10
Err there's a Dell Studio 1535 ??
Anyways run alsamixer at the console and check if all sliders at max
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline
Old 19-10-2008, 01:16 PM   #3 (permalink)
Dark Star's Avatar
Changing the kernel might fix the problem ! Or tried what awilliamson tol you !
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 20-10-2008, 08:54 AM   #4 (permalink)
all sliders are at the max position.... I tried changing the kernel also....
sarincv is offline
Old 28-10-2008, 06:35 PM   #5 (permalink)
I solved the problem in suse.... I think the problem is, two sound cards are listed on executing that lspcidrake command....
1) ATI sound card
2) Intel
The default sound card selected is the 1st one... in opensuse, I was able to change the default soundcard through yast... in Mandriva, I did'nt find any option to set the default one.... can anyone help me to set the default sound card???
sarincv is offline
Old 28-10-2008, 11:11 PM   #6 (permalink)
Dark Star's Avatar
DIdn't this helps ?
Control Center - > Hardware - >Sound ?
Please let me know if it works !
Regrads
Old 29-10-2008, 08:34 AM   #7 (permalink)
no.... it doesn't...
sarincv is offline
Old 29-10-2008, 08:55 AM   #8 (permalink)
Juke Box Hero
Assuming you aren't using the onboard sound, you can always disable it in the BIOS to avoid conflicts.
Hitboxx is offline
Old 29-10-2008, 05:07 PM   #9 (permalink)
actually that ATI is my graphics card.... I want to use intel as my default card... I will try to disable it in BIOS and let u know....
sarincv is offline
Old 02-11-2008, 08:19 AM   #10 (permalink)
Call me Sumit
esumitkumar's Avatar
same prob is coming wid me ..really frustrated
First dload suse 11 --- it wasnt shrinking windows partition so not installed
then ubuntu 8.10 -- it was slow
then dloaded mandriva 2009 - now no sound coming
grrrr..wat to do ? isnt there a readymade linux which can do automatically itself ?
esumitkumar is offline
Old 02-11-2008, 01:22 PM   #11 (permalink)
Dark Star's Avatar
^^Whats your sound card , post the output of lspci..
Or try disabling Pulse Audio from Mandriva Control Center -> hardware -> sound..
Some card have problem with Pulse Audio
Old 02-11-2008, 05:48 PM   #12 (permalink)
Call me Sumit
^^ intel 915 PM MB....also same prob with linux mint
hows XFCE desktop any reviews ?
Old 03-11-2008, 08:10 AM   #13 (permalink)
Dark Star's Avatar
Disable Pulse Audio Sound Server. .From Mandriva Control Center..
Old 03-11-2008, 08:58 AM   #14 (permalink)
Call me Sumit
hmm..actually itne exps k baad im reading vishal's website askvg.com and it really made my XP super duper fast
Old 03-11-2008, 11:11 AM   #15 (permalink)
Dark Star's Avatar
People like you can't be helped , you guys just pops here and there and finally switch from where you come
You can't learn anything by doing this.. Everything has a solution but if uyou won't try you won't get it either
Old 03-11-2008, 05:07 PM   #16 (permalink)
Call me Sumit
^^sorry and he he he
Old 03-11-2008, 05:21 PM   #17 (permalink)
my problem got solved....just try this... Open up Kmix (left click)
Click on "Mixer"
Under Settings (top bar) click onto "Configure channels".
Tick "Analogue Loopback" and click "OK"
Back in your Mixer Window, tick "Mute" analogue loopback.
that will get rid of the hissing and pop sound.
Right click in the taskbar on KMix
Click on "Select Master Channel"
Set it to "PCM"
Keep your front volumes up all the way in the main Kmix window and use PCM to adjust volume.
sarincv is offline
Old 03-11-2008, 11:41 PM   #18 (permalink)
Dark Star's Avatar
Where's Analog Loop back ? I couldn't find it in my Mixer ? Can you please pos ta SS !
Old 04-11-2008, 08:44 AM   #19 (permalink)
oh man... I'm in office and I can't post a screenshot... Did you check configure channel in settings??
sarincv is offline
Old 04-11-2008, 12:34 PM   #20 (permalink)
Dark Star's Avatar
Yeah !
Autodesk has announced the new 3ds Max 2009 and followed with new 3ds Max Design 2009 elenec Random News 4 30-12-2008 10:55 PM
Mandriva 2009.0 Discussion Thread Dark Star Open Source 35 27-10-2008 07:42 PM
Symantec introduces 2009 range of products including NORTON ANTIVIRUS 2009 apoorva84 Technology News 34 19-09-2008 11:01 PM
No sound in Mandriva Dumbledore Open Source 2 13-06-2007 10:29 PM
- by kool
