Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 29-04-2005, 01:16 AM   #1 (permalink)
Default About messaging other computers on LAN
Hi guys,
I wanted to ask that in my college, they have implemented something like virtual private network for the lan, in which only the computers connected to a single hub can be seen in network places, for example only two hostels which are connected. rest can be accessed from that hostel through ip address. earlier, we had full access. now how do we send lan messages to one-another. we used to use skype or lantalk xp, but our net connection's limited, so skype's out of question. some otehrs that i used dont showor allow to chat with students of other hostels which do not shre the common hub. so is there any software that would allow us to send messages to each other?
Athlon 64 2800+ | MSI K8M-Neo-V | Seagate 160 GB PATA | 512 MB Simmtronics DDR400 | Creative Inspire 5200 5.1 | Philips 107E5 17\" Monitor | Sony DVD-CDRW | Microsoft Internet Keyboard+Logitech MX518 | XFX Geforce 6600GT 128MB AGP |
HellGuardian is offline
Old 29-04-2005, 05:20 AM   #2 (permalink)
The first impression that I get after I read your post was the network has been segmented.Subnetting may also be the case.
Can you provide a few more details with regard to IP addressing structure,topology?
www.Oobertech.net
digen is offline
Old 29-04-2005, 05:26 AM   #3 (permalink)
Use NET SEND {name | * | /DOMAIN[:name] | /USERS}
It Sends messages to other users, computers, or messaging names on the network. The Messenger service must be running to receive messages.
You can send a message only to an name that is active on the network. If the message is sent to a username, that user must be logged on and running the Messenger service to receive the message.
name: Is the username, computername, or messaging name to send the message to. If the name is a computername that contains blank characters, enclose the alias in quotation marks (" ").
* Sends the message to all the names in your group.
/DOMAIN[:name] Sends the message to all the names in the workstation domain. If name is specified, the message is sent to all the names in the specified domain or workgroup.
/USERS Sends the message to all users connected to the server.
message Is text to be sent as a message.
lubu is offline
Old 29-04-2005, 06:29 PM   #4 (permalink)
Default About ip structure
We have beeen give custom ips to be entered manually in tcp-ip settings. each hub that is common has the third number same, for example two hostels have xxx.xx.8.xx, then each computer in that hostel has 8 as third. others have 12, 16 and so on. the subnet mask, dns and rest r same for everyone.
we have used net send but its bogus in comparison to lantalk.
Old 07-05-2005, 05:22 PM   #5 (permalink)
The best way is use NetMeetingĀ® in windows.
Get the ip of the PC u want to connect and just make a call on his IP. Netmeet should be running at both machines at same time. similary u can make a call for n number of machines on ur network and all can chat, Send files, Recieve Files, and many more.
Netmeet is really Gr8, U can send a Single files to n number of users connected at the same time.
How to install Netmeeting.
Just type "conf" in run to start the Netmeeting Setup Wizard.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 17-05-2005, 09:54 AM   #6 (permalink)
There is a software called network chat, search it on google, vgood soft for chatting using netwrk
Old 17-05-2005, 11:59 PM   #7 (permalink)
sujeet2555's Avatar
yaa use netsend simple
s.k.
sujeet2555 is offline
Old 26-05-2005, 03:31 PM   #8 (permalink)
Default Finally i got it, thanks all
Hi!
Finally, something good, that netmeeting u suggested is really really good. we used it and it rox.
and that network chat is crap. i tried it.
tnx
Old 26-05-2005, 03:54 PM   #9 (permalink)
expertno.1's Avatar
suhasingale
is the best use
but also use
multicomm
it wil satify u
expertno.1 is offline
Old 12-06-2005, 08:43 AM   #10 (permalink)
Default problem
i've just found a problem with netmeeting. while using netmeeting, direct3d is disabled, and hardware acceleration is also disabled. i checked this by running dxdiag while netmeeting was running. it told that directx hardware acc. is disabled as netmeeting is running. so how to overcome this? any way?
- by kool
