Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 19-04-2005, 08:29 PM   #1 (permalink)
Default Accessing LAN Problem
i am using Win XP service pack 2 ...i just got a sify connection. the prob is that i cant access my LAN sometimes. its only available occassionally otherwise i get the messg ....workgroup not accessible u maay not hav permission....when i can access there are around 50 comp. so i believe this is the prob of XP and i had faced similar prob earlier when i had a diff connection. is it possible to rectify this error whereby i can access the lan all the time
sabman is offline
Old 19-04-2005, 11:27 PM   #2 (permalink)
Tell us more about the topology of the lan, the ip addresses used by you. I think its a case of faulty routing only not a major headace.
**** happens
pradeep_chauhan is offline
Old 20-04-2005, 02:03 PM   #3 (permalink)
Hi,
I think Windows Xp giving you the problem.
Install a different OS on your machine. If this can't solve your problem you should look onto the lan cable.
One other way to check is the lan ok or not is
OPEN RUN FROM START MANU TYPE-
ping your ip address
ping gateway ip address
ping 127.0.0.1
If all the ping successfully received data then it is fault of your OS.
Otherway your IP or Network card has fault. Depends upon your ping results
Purnendu Mukherjee
CCNA
purnendu100 is offline
Old 20-04-2005, 04:42 PM   #4 (permalink)
what was that ?
install a diff os on ur system ?
what the ?
windows xp's networkin capabilities are obviously and evidently much better than its predecessors ...
when in doubt, DONT POST
sabman u can try reinstallin ur tcp/ip resetting ur winsock
follow this link
http://www.xp-smoker.com/freeware.html
but before that note down all ur networkin configuration
No Mercy, No Limits.
theraven is offline
Old 20-04-2005, 05:09 PM   #5 (permalink)
Guys
what i see of the problem is that the defaoult gateway for the lan has been changed to that of the adsl modem and its possible that the IP sub net used is the same so all the trafic even for the local lan is being sent to the adsl modem thus causing the problem. As the lan was working ok before the addition of the modem.
**** happens
Old 20-04-2005, 05:19 PM   #6 (permalink)
Quite a possibility pradeep but I think we should wait for the author to reply with a few more details.
www.Oobertech.net
digen is offline
Old 20-04-2005, 09:22 PM   #7 (permalink)
right now i can access the LAN fine. no problems with it . Its just that sometimes its just doesnt allow me to access it. i dont think its a problem with the modem or the router . just something with xp definitely.
sabman is offline
- by kool
