Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 22-03-2005, 08:18 PM   #1 (permalink)
Default if in server have 2 lancard so how can i double my lan speed
I have a Inter server Board with 2 lancard..!!
i just heard that if we do teaming on 2 lancard then i can transfter my data just double speed ..!!
if this is true then
how can i do that???
Have A Nice Day....!!
pr@k@sh is offline
Old 22-03-2005, 08:33 PM   #2 (permalink)
enoonmai's Avatar
An Intel server board? Man! How on Earth did you get your hands on one? To take advantage of higher data transfer rates, you would need to install Windows 2000 Server / Server 2003, then use the built-in Network Load Balancing function to balance and share the load and make effective use of your bandwidth.
Playing FEAR XP/LSW2
enoonmai is offline
Old 22-03-2005, 11:54 PM   #3 (permalink)
Even on win XP just select the two cards right click and select bridge them the throughput doubles. If its linux then enable bridging in the kernel recompile the kernel and you double the BW.
**** happens
pradeep_chauhan is offline
- by kool
