Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 08-11-2007, 03:24 PM   #1 (permalink)
Default Networking problem
I want to network PC 1 & PC2 for internet. I'm having problem with PC 2.
Pic 1 : PC1 and PC2 can connect to the internet and everything is fine. But i need to move PC1 to the room where i kept my router.
Pic 2 : Thje 60m cable is cross cable, PC1 & PC2 are connected but not the router,
Pic 3 : PC1 connected to the net, I interchanged POC1 and PC2 but PC2 is not connected. I'm using Realteck onboard for PC1 and via ethernet for PC2
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
Old 08-11-2007, 04:13 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Networking problem
First of all 60meters is a lot of distance! What quality CAT cable do you use? Coz at that distance almost all the times i've seen that there is very poor SNR.
Secondly, from what I see the router is wifi enabled and you'd want PC1 to be moved near the router. If that is the case then but a PCI wifi card for less than 900 bucks. Connect it directly (wireless connection) to the router while maintaining your switch + PC2 setup (untouched). This is the most simple and cost effective way!
infra_red_dude is offline
Old 10-11-2007, 08:35 AM   #3 (permalink)
thanks for the reply. Actually my router is not wifi enabled. i just used a pic from the internet. What i suspect is the Onboard Lan card of PC2. Since PC1 is getting the signal even after 60mts. PC2 is using via compatible card (onboard) while PC1 is using REalteck. I will try to get a good lan card for PC2 and see.
valtea is offline
Networking problem ra_sriniketan Software Q&A 3 15-06-2007 08:09 PM
Networking Problem..............? satyamy Software Q&A 3 12-04-2007 01:04 PM
Networking problem .......... see this... rahul_becks23 Software Q&A 17 08-02-2007 02:26 AM
please help me with my networking problem aftab_darogar Hardware Q&A 1 23-09-2006 04:58 PM
Networking Problem rajzoo1 Networking 3 26-05-2005 08:02 AM
- by kool
