Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 07-10-2007, 09:58 PM   #1 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default Lan connection
Plz help me 2 connect two computers using lan.Plz tell me the settings 4 it.Hurry .Thnks in advance.
JohnephSi is offline
Old 07-10-2007, 10:00 PM   #2 (permalink)
"The Gentleman"
vish786's Avatar
Default Re: Lan connection
Look here
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 07-10-2007, 10:15 PM   #3 (permalink)
anand1's Avatar
First step by step
1. for connecting two PC, take a LAN wire either CAT5 or CAT6 grade and of any company like D Link etc. then make a clip with RJ45 in cross connection. Because like devices are always having the cross connections like two PC Switch or Modem.
2. Now Chek if you have installed your NIC card or the LAN card driver. if it is done then follow this.
open
My Network Places----View Network Connection
and here you will see the local area connection icon clik on it
3.then follow
go to Properties---Internet Protocal(TCP/IP) and then properties
another wizard with an IP address to fill up will open.
4.give an ip to both the computer in the range of
192.168.1.1 to 191.168.1.254
Subnet mask 255.255.255.0
Default gateway will be the ip add of the other computer which you have ginen and the same default gateway for the other computer will be the ip of the other omputer.
4. leave the DNS entry an close the wizard and it is done.
ex:
IP configuration for PC 1
IP Address- 192.168.1.5
Subnetmask-255.255.255.0
Default gateway- 192.168.1.10
IP configuration for the PC2
IP Address 192.168.1.10
Subnet Mask-255.255.255.0
default gateway- 192.168.1.5
To chek the connection:
Plug in the wire in both the pc
then open
start- run - cmd- enter
command promt will be open
type ping - 192.168.1.10 enter from the first PC
and it TTL comes the connected
this all can hopefully set up a two PC LAN connection
Technology On The Fly
anand1 is offline
Old 08-10-2007, 12:05 AM   #4 (permalink)
JohnephSi's Avatar
Plz show me the picture of RJ45 .I prefer picture of the connection of the lan if possible.
Old 08-10-2007, 12:14 AM   #5 (permalink)
"The Gentleman"
vish786's Avatar
1st three picture
- Dijkstra
vish786 is offline
which net connection should i take tanmay_rajvanshi QnA (read only) 15 16-07-2007 04:26 PM
Need help with DSL connection thadeus Software Q&A 8 12-08-2006 06:49 PM
something isn't right with my net connection..... techmax Software Q&A 7 22-11-2005 11:47 PM
net connection rowdy8344645 Software Q&A 4 27-10-2005 07:44 PM
- by kool
