Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 12-09-2007, 07:11 AM   #1 (permalink)
Exclamation Remote shutdown in a LAN connected environment
hi,
in command prompt , there is a option for remote shutdown of computers.
syntax
shutdown -m \\computer name -s
but when i try it, it says access denied. wat should i do to make it work, this would really be helpful.
thank u in advance.
sai_cool is offline
Old 12-09-2007, 07:02 PM   #2 (permalink)
Formerly Spashy
Sparsh007's Avatar
Default Re: Remote shutdown in a LAN connected environment
Description of the Shutdown.exe Tool
Shutdown.exe uses the following syntax:
shutdown \\computername /l /a /r /t:xx "msg" /y /c
You can use the following switches with Shutdown.exe:
• \\computername: Use this switch to specify the remote computer to shut down. If you omit this parameter, the local computer name is used.
• /l (Note that this is a lowercase "L" character): Use this switch to shut down the local computer
• /a: Use this switch to quit a shutdown operation. You can do this only during the time-out period. If you use this switch, all other parameters are ignored.
• /r: Use this switch to restart the computer instead of fully shutting it down.
• /t: xx : Use this switch to specify the time (in seconds) after which the computer is shut down. The default is 20 seconds.
• "msg": Use this switch to specify a message during the shutdown process. The maximum number of characters that the message can contain is 127.
• /y: Use this switch to force a "yes" answer to all queries from the computer.
• /c: Use this switch quit all running programs. If you use this switch, Windows forces all programs that are running to quit. The option to save any data that may have changed is ignored. This can result in data loss in any programs for which data is not previously saved.
Detailed here:
http://support.microsoft.com/kb/317371
World Cup T20 News: http://wct20talk.com
Sparsh007 is offline
Remote ShutDown using XP readermaniax Software Q&A 6 04-07-2010 05:42 PM
Remote Shutdown mohanty1942 QnA (read only) 7 26-03-2007 09:35 AM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
remote assistance or remote desktop ? mkmkmk QnA (read only) 7 10-03-2006 09:35 PM
- by kool
