Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 31-07-2007, 10:04 PM   #1 (permalink)
bajaj151's Avatar
Default NFS-U2 Lan Play
How do I play NFS-U2 between 2 pcs connected through LAN ??
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 01-08-2007, 09:35 AM   #2 (permalink)
sharma_atul85's Avatar
Default Re: NFS-U2 Lan Play
4 dat frst u need a lan card then theres a option in game to play on lan ..go 4 it..
sharma_atul85 is offline
Old 01-08-2007, 10:28 AM   #3 (permalink)
bajaj151's Avatar
ya..I know..LAN card is require for the LAN play.
But I want to know, how to connect i.e. all the ip setting n all......
Old 04-08-2007, 11:52 AM   #4 (permalink)
bajaj151's Avatar
Can anyone tell me the whole procedure for LAN Play in NFS-U2 ??
Old 07-08-2007, 03:04 PM   #5 (permalink)
dear for that first of all you need a LAN card installed on both d PCs...then start file and printer sharing between both PCs ..after that on one PC there is an option to host the game ....going through lobby option u ll host the game then tell another person to join ur game .....thats it ....hope u can make it..
Old 07-08-2007, 06:00 PM   #6 (permalink)
bajaj151's Avatar
No...its not working.....I connects to lobby......but my friend on second pc...not able to connect........
Is there any patch for this ??
Old 07-08-2007, 06:04 PM   #7 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Wink Re: NFS-U2 Lan Play
boss try checking the firewall settings.....if possible try disabling the firewall....nad ya do check if the game versions are same
Wadadadada!! ??
Ambar is offline
Old 11-08-2007, 11:18 PM   #8 (permalink)
bajaj151's Avatar
ya i checked both....firewall as well as versions.......both are correctly set...
what should I do now ??
Old 12-08-2007, 10:02 AM   #9 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
tried applying the latest patches
Wadadadada!! ??
Ambar is offline
Old 12-08-2007, 11:47 AM   #10 (permalink)
!FREEWARES!
Akshay's Avatar
@bajaj
Try manually assigning IP addr to ur PC's thru netwrk connection - rite click ur LAN - properties.Assign diff. nos to both PCs. After dat, ping ur pc's
E.g: 1st PC IP addr is 192.168.1.25 n 2nd PC it is 192.168.1.26. Now in 1st PC, go to Start - Run - command - at commnd prompt type - ping 192.168.1.26. Repeat d same procedure on 2nd PC n replace 26 wit 25. C if it is successful...
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
I would play this again and again techtronic Gamerz 34 14-02-2007 02:47 PM
how to play asf files???s refusing to play mayneu QnA (read only) 4 21-11-2006 09:42 PM
I cant play CD-R's in my CDRom, can play CD's , why Charley QnA (read only) 5 22-02-2005 08:15 PM
Why couldn't i play dvd in a cd rom? kunwar QnA (read only) 12 21-02-2005 05:57 PM
How to play NFS u ? vijaythefool QnA (read only) 4 31-12-2004 09:48 PM
- by kool
