Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 13-06-2007, 12:07 AM   #1 (permalink)
Question A Wifi-Orkut Problem
Hello everyone,
Our college is maintaining a wifi internet system. We were able to access orkut since last january and then it was not the case. I suppose they have blocked port 80 . Then I found another way as to getting into the site via SSL. But from last april I am not able to get in such a way. When I searched I found orkut has stopped SSL support . Now heres my question, can anybody tell me a way to access orkut from the same wifi network. I suppose this is a challenge but if somebody can I will be obliged ...
Sonofmoon is offline
Old 13-06-2007, 12:19 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: A Wifi-Orkut Problem
try using proxy sites like
atunnel.com
gateway.oceanlake.com
Pathik is offline
Old 13-06-2007, 10:54 AM   #3 (permalink)
use www.powerscraps.com .............!!!!
bhavesh_mca is offline
Old 13-06-2007, 11:03 PM   #4 (permalink)
Thank you for your replies and I expect more. Now I have another doubt. Are these proxy sites safe to login?? Since we are logging in using our Gmail account ID! And Mr.bhavesh can you tell me how to login to powersrap, I have tried my orkut ID and Password but it is again coming to type the account Password again
Old 14-06-2007, 10:21 AM   #5 (permalink)
umm......... do u have ur account of orkut using Gmail or any other mail provider........ powerscrap support just for gmail...... you can try
www.mathtunnel.com
www.kproxy.com
Old 14-06-2007, 11:04 AM   #6 (permalink)
101101
try www.orkuch.com
Cheers,
Kunal
Finding answers is simple, all you need to do is come up with the correct questions.
crystal_pup is offline
I am going to Setup WiFi LAN (WiFi experienced user's views invited) Ricky Hardware Q&A 2 23-10-2006 06:08 PM
Need to know about Wifi xpress84 Networking 1 13-06-2005 11:11 PM
- by kool
