Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 01-05-2007, 07:29 PM   #1 (permalink)
pritish_kul2's Avatar
Default Networking
i have a laptop and a desktop(both HP). i want to do networking between the two . which wires would i need and the steps to do it.
thnks in advance.
pritish_kul2 is offline
Old 01-05-2007, 08:38 PM   #2 (permalink)
Formerly Spashy
Sparsh007's Avatar
Default Re: Networking
RJ-45 cables with the plaugs ofcrse and jus connect it to the RJ-45 port of both
go here for more info
http://en.wikipedia.org/wiki/RJ-45
World Cup T20 News: http://wct20talk.com
Sparsh007 is offline
Old 01-05-2007, 08:40 PM   #3 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
check these:
from tom'shardware site ->
http://forumz.tomshardware.com/ce/co...pict50943.html
n this is for dummies ->
http://www.dummies.com/WileyCDA/Dumm...-HARDWARE.html
i used Google
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 02-05-2007, 07:00 AM   #4 (permalink)
i got a cable like the one spashy said with my mtnl broadband connection. can i use that?
i connected that mtnl one between the two. but it din't detetct only. i think i need some other cable.
Old 02-05-2007, 01:05 PM   #5 (permalink)
Formerly Spashy
Sparsh007's Avatar
nope u cant use tht 1 ie i think RJ11
see here for more
http://en.wikipedia.org/wiki/RJ11,_RJ14,_RJ25
Old 02-05-2007, 01:12 PM   #6 (permalink)
virus_killer's Avatar
Its better to use wireless card , It is like a LAN card , you just have to attache to your desktop computer so that you can also use your laptop without connecting any kind of cable. You can make wireless connection between your desktop computer and Laptop
virus_killer is offline
Old 02-05-2007, 01:37 PM   #7 (permalink)
eagle_y2j's Avatar
but make sure that ur lappy is wifi enabled or you may need to buy external wifi card
Registered LINUX USER #438929
eagle_y2j is offline
Old 02-05-2007, 01:40 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
LAN Cable (RJ-45) wud cost you max. 30 bucks , you can get it in any PC peripheral shop.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 02-05-2007, 02:00 PM   #9 (permalink)
use cross crimped rj-45 cable...
Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour, and it seems like a minute.
That\'s relativity - Albert Einstein
great_manish is offline
Old 03-05-2007, 05:28 AM   #10 (permalink)
Yeh, Sorry forgot to write that
USB Networking altimate Networking 2 27-09-2006 11:24 PM
Help me with Networking ... PLZ... mrbhide_techie Software Q&A 5 18-09-2006 12:22 PM
Immediate Help - Wi-Fi networking ashu_dps Networking 3 28-08-2006 02:31 PM
Networking Q khandu QnA (read only) 3 18-04-2005 08:32 AM
Networking club_pranay Networking 13 14-09-2004 12:12 PM
- by kool
