Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 29-01-2005, 11:39 AM   #1 (permalink)
Default best language for sockets programming!!
hey guyz can anyone tell me which is the best language for sockets programming?? and how many of u are doing some work in sockets programming?? i wanna do it in C++ but dont have header files like->-> netdb.h,sockets.h etc etc from where i can get those??
Ashootosh is offline
Old 29-01-2005, 01:14 PM   #2 (permalink)
tuXian's Avatar
personally I prefer C to C++ as all the intricacies of Object orientation are gone(may be at a expense). But its a lot easir in C.
The best thing is to use linux. If u have got a Live CD then need not install linux too.
Happy Socket programming.
You know it's love when you memorize her IP to skip DNS overhead.
tuXian is offline
Old 31-01-2005, 02:55 PM   #3 (permalink)
r u using knoppix? and does ur live CD contains the header files necessary for sockets programming? i know c/c++ are the best but from where can i have knowledge about sockets programming in them??
Old 31-01-2005, 02:58 PM   #4 (permalink)
The WinSock (Windows Sockets) API is a socket programming library for Microsoft Windows Operating Systems.
It was originally based on Berkeley sockets. But several Microsoft specific changes were employed.
for Socket programming in C++ you need to include the following files
#include <winsock2.h>
Add a refrence to winsock library
Take Project-Settings-Link and add ws2_32.lib to the library modules list.
I am talking about VC++
for detailed info visit http://www.codeproject.com/internet/
Sudhir Mangla
http://DevelopersVoice.com
(VC++ FAQ, MFC FAQ, C++ FAQ)
http://Programmerworld.net
(Free books and source code)
sudhir_mangla is offline
Old 02-02-2005, 10:19 PM   #5 (permalink)
FooBar Guy
GNUrag's Avatar
Writing socket programs is a lot easier in high level languages. Perl and Python are best suited for writing Socket scripts. You must use Perl to believe it...
GNUrag is offline
Old 03-02-2005, 01:50 PM   #6 (permalink)
i have done some work in perl but i dont know how to make an exe in perl, the file which we get has extension .pl (now i dont know how to use this?). and also no one has answered the question->-> from where can i have header files like sockets.h etc. perl contains these files( will they work with c/c++)
- by kool
