Re: hide pc on lan
Hi Ishaan,
I am guessing you want computer A to be invisible in LAN WORKGROUP but still be able to access the network computers. I am assuming that when you say that you dont want other systems to see you, you also dont want to share any data on your system A. In that case, I think that removing all shares should do the trick. Not sure about it, it might depend on the OS u are running on A and on the other networked computers...
Try and let me know, also if it does not work, pl. specify OS in system A and in the other networked computers....
Arun
