Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 16-01-2007, 09:43 AM   #1 (permalink)
Ganeshkumar's Avatar
Question Connecting 2PCs using Modem?
Hi..
Is it possible to connect my WinXP & Win98 PC using their Modem for file sharing ?? Without connecting it to internet?
Is there anyother simple way ? I dont have lan port in my win98.
Waiting for re guysss
Ganeshkumar is offline
Old 16-01-2007, 11:34 AM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: Connecting 2PCs using Modem?
use external tranfer device... like pen drive or external HDD or write a cd or a dvd and transfer... modem cannot do that work for u
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 16-01-2007, 11:25 PM   #3 (permalink)
shantanu's Avatar
i dont think DATA TRANSFER IS POSSIBLE THAT WAYS !!! YES INTERNET CAN BE DIALED BUT THAT ALSO IN ONE PC AT A TIME NOT IN BOTH
shantanu is offline
Old 16-01-2007, 11:48 PM   #4 (permalink)
Super Hero - Super Powers
n2casey's Avatar
@ Ganeshkumar
Yes u can. I m unable to remember the name but I have a s/w which allows u to that. I will search & will tell u soon about it.
Well, I have searched & found something which can help u. Visit
http://www.jagshouse.com/modem.html
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 16-01-2007, 11:52 PM   #5 (permalink)
shantanu's Avatar
SORRY!!! IF I GAVE WRONG INFO BUT THAT METHOD WONT WORK !!! IhAVE TRIED THAT BEFORE ALSO
shantanu is offline
Old 16-01-2007, 11:57 PM   #6 (permalink)
n2casey's Avatar
Smile Re: Connecting 2PCs using Modem?
No prob friend. U have provided everything right according to ur knowledge.
May be u have made any mistake. I will try it & will tell u the result.
n2casey is offline
Old 17-01-2007, 12:00 AM   #7 (permalink)
Alive Again...
satyamy's Avatar
u need lan connection
from modem it is not possible
buy two lan cards
it'll cost u just rs. 250/- per card
i.e. Rs. 500 = cost of 1 modem
n also u need one Lan Connecting Wire
satyamy is offline
Old 17-01-2007, 01:30 AM   #8 (permalink)
shantanu's Avatar
^ PERFECT as LAN IS THE MOST RELIABLE WAY and the cheapest too
shantanu is offline
Old 17-01-2007, 02:43 AM   #9 (permalink)
No longer here..
how about using hyperterminal to dial-out from one pc and so connect the 2 pc's ....but the speed will like dialup connection ...and also its like a sendfile utilty + chat ..thats it.Heavy phone bill by the way...the one dialing out has to pay.
indian_samosa is offline
Old 17-01-2007, 05:22 PM   #10 (permalink)
Thank u frnds...
I heard that even using serial port one can interconnect 2 Pcs... Though it wont be practically better.. I want to try it
Thanks..
__________
Originally Posted by n2casey
@ Ganeshkumar
Thank u frnd..
I am tring out... Also send me any other detailed information if possible..
byeee
- by kool
