Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 12-01-2007, 09:50 PM   #1 (permalink)
From Sri Lanka
thilina's Avatar
Default Help me to port forward in my Router
I have got a Cnet CNAD 800EF modem.How can I enable port forward in it??
thilina is offline
Old 12-01-2007, 10:37 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: Help me to port forward in my Router
hey buddy try http://portforward.com/english/route...outerindex.htm
although yours is not mentioned there.
you can always try googling this query
Arsenal_Gunners is online now
Old 12-01-2007, 10:43 PM   #3 (permalink)
From Sri Lanka
thilina's Avatar
chkd that site too.
googled
But any place doesnt tellabt my modem
thilina is offline
Old 12-01-2007, 11:09 PM   #4 (permalink)
String Phreak
mediator's Avatar
Is that a router or a dialup modem?? In latter case u don't need to port forward!
mediator is offline
Old 12-01-2007, 11:16 PM   #5 (permalink)
From Sri Lanka
thilina's Avatar
its a router.
In azeureus port testing,it gives me a NAT error.
Thats y i thought that i neeed port f. enabled[it is also said in the azuereus wiki]
thilina is offline
Old 12-01-2007, 11:57 PM   #6 (permalink)
String Phreak
mediator's Avatar
Well @thilna, I have encountered that problem myself. But due to some fault in my router itself, its not able to add entries in "port forward" section. But recently installed a wireless router and my problem was gone! So can u do the same as a last resort!
U may read ur router manuals. I think that wud be the best source. Well u can just explore tooo.
mediator is offline
Old 13-01-2007, 12:19 AM   #7 (permalink)
TheSaint
NucleusKore's Avatar
Its not so complicated. I just checked and saw that your router is capable of uPNP (universal plug and play).
Please open your router by typing 192.168.1.1 in your browser, login to your router, and search for the uPNP enabling checkbox, tick it, restart your router.
Now launch azureus and run the configuratiion wizard from the tools menu, at one point you will be prompted to enable uPNP in Azureus which you must do. Now your set !
Your Azureus will "talk" to your router and set the routing path. Just ensure that azureus program access permissions are added to your firewall.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 13-01-2007, 12:22 AM   #8 (permalink)
Waiting for 3 Miracles...
saurav29's Avatar
login into the modem.......
aka (http://192.168.1.1
username: admin password: admin)
if you get a web interface your problem is half solved........
if not then you need to telnet to 192.168.1.1 user admin/admin to login...
you will be provided with interface no worries more or less they are same...
look for NAT or Port triggering or port forwarding this kind of settings ......
You will eventually find it.... (mine comes under Advanced>NAT>add....) once you located it add any name... does matter azerus for instance assign a starting port... any take example 50001 and end port 50001 (In case you need to forward only one port) next setting will be for protocol (aka TCP or UDP or Both....... select Both) and last will be the connection you are using ptp over lan or bridge select whichever you are using most probably will be ptpoelan and save changes and an exception will be added to the router....
save and reboot the router aka( option will be there... just click it)
NOw you need to go in the preferences of the softwares... aka (azerus here for example and remove randomize everytime it starts and assign the port you just trigger aka(50001) and you will be done...
to save the above hassle you can use utorrent with unpn option it can forward any port (provided your isp supports it..), some minor speed will be lost but not noticeble...
saurav29 is offline
Old 15-01-2007, 06:51 PM   #9 (permalink)
From Sri Lanka
thilina's Avatar
Thanks thanks thanks to all of u guys.
I hope this will work.
Ill try it and say the result to u guys tomorrow
thilina is offline
- by kool
