Results 1 to 12 of 12
  1. #1
    Stabbing my shoe
    Jan 2005
    Ahmedabad
    Unhappy [Modem Problem] No dialing.. Please help..
    Hi! Everyone..
    Well, I use a SmartLink 56 kbps Fax modem to conect to the internet. Actually, I stay away from home and use it only when I come home.. Nobody uses it in my absence. Few days back I left my PC working fine and no glitches in connecting or nay such stuff with a speed of around 50.5 kps.
    However, I just returned yesterday and saw that my modem wasn't dialing at all.
    The modem always dials in Pulse and the dialing is heard both on the speaker and modem speaker. This time there was no such sound. I tried altering the settings, dialing at different times, re-connecting the phone wires, changing the modem port but nothing seems to work.
    WHat should I do now? The Modem came with its own CD and I even re-installed its software and drivers. The software has a facility to check any faults. When I run it, it says the modem is all right but the telephone line has a problem.
    But the telephone is connected via the modem. If the telephone has no problems (I even tried dialing 172233 from the phone and it connects to the server all right), how come the wire will..
    Please suggest something... Is there a way to test modems? Whether they are fine or are no longer fit to be used...
    >> Siddhartha
    >> Siddhartha <<
    > http://sidroy.wordpress.com <
    > Beauty lies in the eyes of the Beer Holder <
  2. #2
    True Techie nithinks's Avatar
    Apr 2005
    Default Re: [Modem Problem] No dialing.. Please help..
    Even me too faced the same problem with smartlink modem... there was a hardware problem in my modem.But i cant tell that you are also having the same prob.. but in my opinion (75%..!) .. there is a fault in the hardware..
  3. #3
    Right Off the Assembly Line shashank.love's Avatar
    Dec 2006
    HELLO ,this is the solution for your problem
    Go to start ->control panel ->phone and modem options->click on modem ->then in modepm click on properties->now again on modem and now set modem speaker vol->click on apply
    or
    search for
    modem setting in control panel ->now click on speaker and set speaker volume
  4. #4
    Super Hero - Super Powers n2casey's Avatar
    Sep 2006
    Dynamic
    @ //siddhartha//
    Well my suggestion is, check ur modem on other system & also check with other SmartLink modem on ur system (ask a friend, friends r for that )
    Minds are like Parachutes :arrow: They work best when open
  5. #5
    GaurishSharma.com gary4gar's Avatar
    May 2005
    Jaipur
    this is a simple test to check if your modem is fine for not.
    start>setting>control panel>phone & modem>modem's tab>select the modem>properties>diognostics>query modem
    post the result here!
  6. #6
    Broken In [A]bu's Avatar
    Oct 2006
    Please See Your Back...
    u can try this
    open the casin
    take out modem and again keep it on the slot
    fine it may work...
  7. #7
    Nov 2006
    india, new delhi
    hi ..it may be a hardware prolem ,i think it conflicts with other hardware "IRQ".
    first take out ur modem from mother bord , just wait 5/6 minutes ,then insert back , then instal ur modem through cd which had come along ur modem ,
    then go to "mycomputer>properties>device manager".......
    here u can chek the confliction of ur medem "IRQ". if it conflicts with oter...
    then change the number ,....
    then go control panel and set up ur modem .
  8. #8
    Broken In anilmail17's Avatar
    Aug 2004
    simple thing dial any number from ur phone and chk that if ur line allow pulse dialling or tone dialing or just change ur dialling rules to pulse mode and then test by calling any number from start>RUN>dialer
  9. #9
    Mobile Freak reddick's Avatar
    Jul 2004
    S.B.S Nagar
    Question Re: [Modem Problem] No dialing.. Please help..
    I too got modem problem...I have dialup conn. of sify.The problem is that i have to try 4-5 times to gt connected n if luckly i gt connected,i got too low speed.Only 31kbps I QUERRY WITH MODEM n here is d report:
    ATQ0V1E0 - OK
    AT+GMM - +GMM: SoftV92 Data Fax Modem
    AT+FCLASS=? - 0,1
    AT#CLS=? - COMMAND NOT SUPPORTED
    AT+GCI? - +GCI: B5
    AT+GCI=? - +GCI: (00,01,02,03,04,05,06,07,09,0A,0B,0C,0D,0E,0F,10,1 1,12,13,14,15,16,19,1A,1B,1C,1D,1E,1F,20,21,22,23, 24,25,26,27,28,29,2A,2B,2C,2D,2E,2F,30,31,32,33,34 ,35,36,37,38,39,3A,3B,3C,3D,3E,40,41,42,43,44,45,4 6,47,48,49,4B,4C,4D,4E,4F,50,51,52,53,54,55,56,57, 58,59,5A,5B,5C,5E,5F,60,61,62,63,64,65,66,67,68,69 ,6A,6B,6C,6D,6E,6F,70,71,72,73,74,75,76,77,78,79,7 A,7B,7C,7D,7E,7F,80,81,82,83,84,85,86,87,88,89,8A, 8B,8C,8D,8E,8F,90,92,93,94,96,97,98,99,9A,9B,9C,9D ,9E,9F,A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,AA,AB,AC,AD,A E,AF,B0,B1,B2,B3,B4,B5,B6,B7,B8,B9,BA,BB,BC,BD,BE, BF,C1,C2,C3,C4,C5,C7,C8,C9,CA,CB,CC,CD,CE,CF,D0,D1 ,D2,D3,D4,D5,D6,D7,D8,D9,DA,DB,DC,DD,DE,DF,E0,E1,E 2,E3,E4,E5,E6,E7,E8,EB,EC,ED,EE,EF,F0,F1,F2,F3,F4, F5,F7,F8,F9,FA,FB,FC,FE)
    ATI1 - 255
    ATI2 - OK
    ATI3 - SoftK56V_B2.1_V7.04.05
    ATI4 - SoftV92 Data Fax Modem
    ATI5 - 181
    ATI6 - SoftK56
    CModem Version 12
    Rksample Version 342
    ATI7 - 255
    Please tell me how to boost that speed...THANKS A LOT BUDDY!
    __________
    AnyOne Please Help...It's so urgent
    Hope 4 d best n Do d right :)
  10. #10
    Stabbing my shoe
    Jan 2005
    Ahmedabad
    Hi!
    @gary4gar I Queried the modem and everytime it shows SUCCESS. I tried everything and even went to my the shop from where I bought the modem and they say there is no probs with the modem but they couldn't check its dialing 'coz NOR THEY NOR ANYBODY ELSE AROUND THEM HAS A LANDLINE.
    Anyways, I am going to test my PC in a day or two on somebody else's landline and see if it works... It seems there is some problem in the phone line....
    >> Siddhartha <<
  11. #11
    May 2005
    Jaipur
    if query modem test is passed by your modem then your modem is fine, check something else must be wrong
    check:-
    phone line for dail tone
    delete the connection in ur pc & create a new one!
  12. #12
    Stabbing my shoe
    Jan 2005
    Ahmedabad
    Well, I tried everything/.// Nothing seems to work.. I wonder what the problem is.. I mean the modem shows NO SIGNS of problems and yet no connection is being established.. I mean it does not dial at all...
    >> Siddhartha <<
  1. dialing bsnl bb from 2 pcs
    By vicky_l7 in forum Broadband and DTH
    Last Post: 03-09-2009, 10:35 AM
  2. Laptop Hang When Dialing CDMA Modem
    By sukanta in forum Software Q&A
    Last Post: 23-01-2008, 02:55 PM
  3. dialing through pc
    By Terahertz in forum Mobiles and Tablets
    Last Post: 19-01-2006, 11:19 AM
  4. Dialing Problem
    By uk_tyagi in forum Software Q&A
    Last Post: 08-12-2005, 06:37 AM
  5. Replies: 21
    Last Post: 09-07-2005, 10:55 AM
