There are a few steps to follow here:
1. Type
192.168.1.1 in address bar of your browser.
2. Type admin in both username & password(default)
3. In the page that opens, click WAN Settings on the left column
4. Select
RFC2684Bridged in the WAN type and then choose
Pure Bridged
5. Click on Apply and Restart the modem when prompted
Now,
i)Go to
Start>control panel>Network connection>create new connection.
ii). Choose the following options step-by step:
connect to the internet
setup my connection manually
connect using a broadband that requires a username and password
ISP name(anything)
username(your ID)
password(your password)
iii)After completing, select
LAN->Properties->internet protocol(TCP/IP)->Properties.
Then select obtain IP address automatically and obtain DNS server automatically.
Now, when you want to use the broadband, just dial in with your ID & pass just like you did with the dialup.
Hope it helps...
Savvy
