mine pc is connected 2 100mbps lan n whenever i start my pc with n/w enable then all applications becomes slower, however when i disable n/w evrything becomes normal ..........
anybody having sloutions plz reply back soon.....
4 times same post ?If it is accidently then you can delete last 3 posts with del
at the right hand side.You r not a new to this forum.You might know all this.
