PC:: Make a SSID named xxx and select manually assign a network key, enter the network key. after that it will promt you to create USb or manually. click manually .. take the config. Laptop: run Wirless Network Setup wizard and select Add new computers ........; enter the setting from the printout. You can use usb flash drive also.
for file and printer sharing, run network setup.
For every action, there is an equal and opposite criticism.
