Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 23-01-2006, 06:21 AM   #1 (permalink)
Default NETworking help..
I have two pc . How can i share resource between? I want to connect them without any hub, cat5. Is there any way to connect them by rs232c or any twisted pair wire. Is nic or modem is necessary ? please help.
shersaha is offline
Old 23-01-2006, 10:45 AM   #2 (permalink)
siriusb's Avatar
If u have no nic card, you can use serial-port-to-serial-port, or usb-to-usb, or bluetooth card/dongle to another to do the network. Which u use depends on the cost of the hardware and its availablity. I would not recommend a serial port one though.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 23-01-2006, 09:07 PM   #3 (permalink)
usb-to-usb?
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
naveenchandran is offline
Old 24-01-2006, 08:30 PM   #4 (permalink)
String Phreak
mediator's Avatar
U connect them with a hub or without a hub doesnt matter. If the machines are on the same lan 192.168.1 i.e one has 192.168.1.2 and other 192.168.1.3 then they'll see each other! I've experimented with it! And for ur problem u can try http://www.thinkdigit.com/forum/view...hlight=#305133
mediator is offline
Old 06-02-2006, 10:39 PM   #5 (permalink)
please give details for serial to serial and usb to usb.
shersaha is offline
Old 06-02-2006, 11:51 PM   #6 (permalink)
siriusb's Avatar
You can network computers by connecting their par ports or serial ports together with a simple two ended wire. But for usb, follow this link.
siriusb is offline
Old 17-02-2006, 06:42 PM   #7 (permalink)
thanks siriusb for help I will go through the link..
shersaha is offline
Old 17-02-2006, 06:43 PM   #8 (permalink)
shersaha is offline
- by kool
