Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 05-01-2006, 01:32 PM   #1 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
Default A Networking Query!! Plz enlighten!!!
Well guys I've this little query about a simple networking aspect.
I've two PC's connected to each other (just the two of them) sharing a common internet connexion.
what I wanna know is that when they are connected then who gets the better share of bandwidth of the connexion? Is it the server or is it the client?
Some of my friends say that it is the client (Yes, client!), while it seems to me that the server gets more benefit.
So tell me what really is the fact?
Both the PCs have Windows XP SP2 installed on them!!!
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 05-01-2006, 02:19 PM   #2 (permalink)
i think it depends on the app u use
for example, sum apps allow u 2 set the bandwidth allocation on maximem...then whichever pc is using that app, it will get more
download accelerators tend to do that, and u can do this setting in p2p programs also like limewire, utorrent, etc
for general use, jus normal browsing, i think the bandwidth is shared equally
ishaan is offline
Old 05-01-2006, 10:28 PM   #3 (permalink)
a_to_z123's Avatar
OK, thx. I got your point.
But what about normal browsing?
Old 05-01-2006, 10:40 PM   #4 (permalink)
choudang's Avatar
its depends on the usage..... which one recieving the highest data..
suppose 1st PC has one page and 2nd one 3 page.. so 2nd PC taking the bandwith.. don't worry.. you can say its sharing the whole connection and bandwidth equally
For every action, there is an equal and opposite criticism.
choudang is offline
Old 05-01-2006, 10:49 PM   #5 (permalink)
In my institution, the server is damn slow, but clients are fast. this is because the server's resources are utilised more than that of a client.
In your case there is only one server and one client, so both will get equally. (If the clients are more, then this may change)
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 06-01-2006, 12:01 AM   #6 (permalink)
if u read my post carefully, in the last line i sed its generally equal
ishaan is offline
Old 06-01-2006, 11:29 PM   #7 (permalink)
a_to_z123's Avatar
Thx....i got the gist of the whole matter!!
- by kool
