How to convert normal BSNL broadband modem to Wi Fi?
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 52
Thread: How to convert normal BSNL broadband modem to Wi Fi?
  1. #1
    Wise Old Owl Rockstar11's Avatar
    Jul 2006
    India
    Default How to convert normal BSNL broadband modem to Wi Fi?
    I have BSNL broadband connection and BSNL ADSL Modem UT-300R2U. It has got two ports ethernet port and USB and Ethernet port. I want to know that is there any facility or a dongle available which can be connected to USB port direct on modem and I can convert the signal to Wi-Fi as then I will have the facility of using my Iphone from anywhere in the home.
    Laptop : Ethernet port
    Iphone : Wi Fi
    can i use both at the same time??
    i dont want to buy Wifi modem and WIFi Router
    and my laptop dont have built in wifi.
    Popular Gadget Deals
    Sony HX20V 20x optical zoom
  2. #2
    Human Spambot pratyush997's Avatar
    Mar 2012
    Earth
    How about getting a WiFi router ! or else use Connectify to make you lappy as hotspot
    Pantech Burst, Sammy S02IN
    [Tutorial] Genymotion | Android On PC (formerly known as AndroVM) - http://www.thinkdigit.com/forum/tutorials/171043-tutorial-androvm-android-pc.html
  3. #3
    Jul 2006
    India
    Default Re: How to convert normal BSNL broadband modem to Wi Fi?
    Quote Originally Posted by pratyush997 View Post
    no I dont want to buy WIFi Router also.
    can a Wireless Usb adapter used as a router?
    i have netgear wireless usb adapter.
  4. #4
    How are you? pravinbv's Avatar
    Jul 2007
    I also have the same question. Can I convert the normal BSNL landline modem in to Wi-Fi modem so that i can use the internet on my laptop without wires. I also have the same type of modem with USB and eathermet port.
    [B][URL="https://plus.google.com/u/0/113104958218535953149/posts"]Add me to your circle on Google Plus[/URL][/B]
  5. #5
    Jul 2006
    India
    Quote Originally Posted by pravinbv View Post
    koi to rasta hoga....
  6. #6
    Jul 2007
    Quote Originally Posted by Rockstar11 View Post
    Today I talked to one of my friend who is in networking field. He said, it is not possible because how will you set the address and how to install the drivers and other things.
    But still then I think it is possible. Anyone here please help.
  7. #7
    Jul 2006
    India
    hmmm.. i am serching if any cheap and small dongle typ device which can connect to direct modem and make WIFI modem... ????
  8. #8
    Jul 2006
    India
    any update?
  9. #9
    Newcomer at Tech tanmaymohan's Avatar
    May 2012
    New Delhi, India
    yup u can plug in the wireless usb adapter and use connectify to share the internet
    if u buy modem my review : I use TP-LINK WR702N to share my connection on my android phone
    Sorry for bad english
  10. #10
    The Mighty Unkel!!! RCuber's Avatar
    Sep 2004
    ಬೆಂಗಳೂರು (Bengaluru)
    Buy a WIFI router with USB/3GModem Support and forget the complications. thats the best solution
    the cake is a lie
    621311.251521
  11. #11
    Jul 2006
    India
    Quote Originally Posted by tanmaymohan View Post
    hmm thx
  12. #12
    learning......
    Sep 2011
    India
    Quote Originally Posted by RCuber View Post
    Price and model please?
  13. #13
    Sep 2004
    ^^ have a look at the Networking session..
    the cake is a lie
    621311.251521
  14. #14
    VirTuaLiZaTioN Freak
    Dec 2011
    Batala, India
    just simply purchase a Cheap VFM Wireless Router - such as TP LInk 740N (online --- 1050/-) and u just need to connect cables --- and it will start working out of the box --- and if u come across any HASSLE - community is here to sort it out.
    Believe me --- GO for Wireless Router rather than Wireless Adapter - for the purpose of Sharing INTERNET
  15. #15
    Apprentice krishnendu's Avatar
    Nov 2012
    Black Hole
    You can not use Wireless and Ethernet simultaneously, its not allowed on BSNL home planes. Which modem you are using, I could have told you details if I knew the modem company name.
    Open firefox or other browser, go to 192.168.1.1 it will ask a ID and Password. Give the ID & pass.
    id: admin and pass: admin
    and then you will see the modem config page. Don't mess with it unless you know everything, just find the wireless option and check on it. thats it.
    | AMD FX 6300 @ 3.5 GHz | Gigabyte 970A-DS3P -5800 | Corsair Vengeance 1600Mhz 4GB | 1TB Western Digital HDD | MSI HD R7770 OC | Corsair CX500 v2 | NZXT Gamma | Samsung LED Monitor S20B300B 50cm | APC Back-UPS 1100VA |
  16. #16
    Jul 2006
    India
    Quote Originally Posted by krishnendu View Post
    Please don't spread this method and the id pass elsewhere. please.
    BSNL ADSL DATAONE Modem UT-300R2U
  17. #17
    Nov 2012
    Black Hole
    Type2 I guess, do as I've said. Find the wireless option by going to 192.168.1.1 and CHECK ON it.
  18. #18
    banana arijitsinha's Avatar
    Nov 2011
    After seeing the images in google search, I dont think it is wireless.
  19. #19
    learning......
    Sep 2011
    India
    @Forum Friends,how about this wi-fi adapter;to be used as hotspot within my House?Can it be used as a hotspot device for BSNL connection?
    I am under BSNL Dataone Broadband 900ULD Plan(wired-ethernet connection obviously).
    Modem :---> D-Link DSL-2520U ADSL2+ modem/router
    How to apply connectify,any configuration/settings or do I need to apply any other tools? Please mention the procedures.
  20. #20
    learning......
    Sep 2011
    India
    Friends,already purchased the Wi-Fi adapter.
    My D-Link DSL-2520U ADSL2+ modem/router has an USB port(also a USB compatible port chord/wire provided).Can I connect the Wi-Fi adapter in this modem,and make it a hotspot access point within my house premises?
    Please reply and help me friends.
  21. #21
    Nov 2011
    NCR
    not possible.any complex usb device need driver install to function & for this it needs either a full fledged OS like windows/linux or it needs a custom OS(like those 3g wifi routers which supports various 3g usb modems).that usb port is v1.1 supporting basic usb devices or pen drives only.
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  22. #22
    learning......
    Sep 2011
    India
    ^^But whitestar,the device may reach me tomorrow or the next day(already shipped by ebay through DTDC).The manufacturers(Leoxsys) are also packaging an auto installation CD for drivers.
    According to them:--->
    Complies with wireless 802.11b/g/n standards with data rate up to 150Mbps
    Standard: 802.11b/g/n, 802.3, 802.3u
    USB 2.0 interface
    Supports 20 MHz/40 MHz frequency width
    Auto-detects and changes network transmission rate
    Provides two work modes: Infrastructure and Ad-Hoc
    Supports software AP and building your wireless LAN.
    Green Power Saving : supports smart transmit power control and auto-idle state adjustment
    Security: 64/128-bit WEP, WPA/WPA2 encryption methods, 802.1x authentication standards
    System requirements: Windows 7/Vista/XP/2000, Mac OS X, Linux
    Adapter size: 23 x 14 x 5 cm
    Net weight: 30 g
    So a bit hopeful my Friend.
    Simply put, D-Link DSL-2520U + Mini Wireless Wi-Fi Nano USB Adapter Dongle WiFi Dongle(LEO-NANO150N), can this be a POSSIBLE or VIABLE connection & configuration for wi-fi HOTSPOT access point?
  23. #23
    Nov 2011
    NCR
    i think you misunderstood.driver install will take place in the device to which it is connected which in your case is D-Link.unless D-Link DSL-2520U comes with inbuilt drivers for LEO-NANO150N which is most certainly not the case it will not work.usb ports in modem/router usually support only pen drives & 3g usb modems(that too from a specified list & not just any 3g usb modem again because of fixed inbuilt drivers in modem/router) & nothing else.if only creating hotspot is your aim then you can simply connect wifi adapter to PC & use connectify free version for basic hotspot features.procedure is very straight forward & for help you can see instructions on connectify web site/help/faq.
  24. #24
    learning......
    Sep 2011
    India
    ^^Sorry friend, I got you. Actually I misunderstood your explanation.Now it's clear.
    Well,keeping the BSNL Broadband connection (900 ULD) through DSL-2520U(D-Link) modem completely HASSLE FREE for my Desktop-PC, what connection will the LEO-NANO150N use as hotspot?
    The hotspot is mainly for my Tablet surfing from another room in my house through wi-fi connection.
    Where from to download connectify software?
  25. #25
    Nov 2011
    NCR
    you can connect LEO to desktop & install connectify lite/free from Lite vs PRO - Connectify
    it should automatically detect the broadband connection & then you can share it.for some detailed instructions you can see this:
    connectify tutorial-connect and use wifi an any device without a router....
  26. #26
    learning......
    Sep 2011
    India
    ^^Friend @whitestar_999,followed the links,downloaded the software;Connectify "lite" version.
    I had also received the LEO-NANO150N USB Wi-Fi adapter today,which I had already connected to a USB port on my PC.I also installed the latest Drivers based on Windows from the "Leoxsys" website.Everything O.K.
    Now,when I installed the "Connectify-lite" software tool ,it is recognising the connection as "ethernet" but is failing to share the network over wi-fi.The info. box (configuration tool box) says that this is applicable (means sharing of ethernet network connection)only on "Pro" versions.
    That means all my attempts are futile?
    Are there any other alternative "Free methods"?
    Please help Friend.
  27. #27
    Nov 2011
    NCR
    their comparison page only states that 3g/4g connection sharing is limited in lite version but no mention of ethernet.anyway try this:
    Virtual Router - Wifi Hot Spot for Windows 7 / 2008 R2 - Home
  28. #28
    learning......
    Sep 2011
    India
    ^^whitestar,I had previously installed Virtual Router(0.9 beta version)tools in Windows 7,which I am into now.
    The Network name(SSID):BSNL-Connect(As per my choice)
    Password: ***********(I gave a combination of alphanumeric characters)
    Shared Connection: Local Area Connection(AS SHOWN IN THE DIALOG BOX)
    Now when I click the button "Start Virtual Router", a message dialog box appears and says: "Virtual Router could not be started"
    Hence no connection.
  29. #29
    Nov 2011
    NCR
    check in services(run services.msc) WLAN autoconfig service is running.if not start it & set it to automatic.
  30. #30
    learning......
    Sep 2011
    India
    whitestar,as per your instructions,I ran and checked WLAN autoconfig.Everything is O.K. and it is already set to started and automatic.
    The Local Area Connection in the network area(Control Panel -> Network and Internet ->Network Connections) shows Broadband (ethernet) as active but the Wireless Network Connection 2(WLAN)connection as disabled and passive.The drivers are shown to be installed without error(within the properties dialog).
    Still running network diagnostics(As administrator) the message is: Problems Found
    "There might be a problem with the driver for the Wireless Network Connection 2 adapter" Detected (yellow exclamation mark)
    Surprisingly within "Device Manager" it is showing that the 802.11n USB wireless Lan card(LEO-NANO150N) ---> The device is working properly(Inside properties dialog).
    There are no yellow exclamation signs within Device Manager.
    Ultimately ???????????????????!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!???????????????????
