High Range Wifi Modem
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 44
Thread: High Range Wifi Modem
  1. #1
    as Sam Fisher rider's Avatar
    Aug 2011
    ThinkDigit Forum
    Default High Range Wifi Modem
    Hello, guys I've a BSNL Broadband connection and ZTE-ZXDSL-531B router wifi modem that comes with BSNL. The problem is that the signal drops after moving 10 feet plus.
    So, I planned to spend money on a modem which should perform high range of connectivity, with at least two antennas.
    My budget is not sure but I want pure performance, it should not be expensive and issues. Also I'm kinda newbie in networking so I need a guide to set password protection for wifi.
    As I searched on internet market, I saw D-Link DSL-2750U, I want to how it is? Is it compatible with USB portable HDD to download torrents and how?
    And what is the difference between 150mbps or 300mbps modem? I've 4Mbps connection.
    Popular Gadget Deals
    Google Nexus 4 16GB running 4.4 KitKat with noise isolated SoundMAGIC PL11
    Nikon D5100 DSLR with 18-55mm VR Kit Lens
    hp pavilion dv6-6165tx powered by Intel Core i7-2670QM 2.2Ghz-3.0GHz | Radeon HD 6770M 2GB GDDR5 | 8 GB DDR3 RAM | 1TB WD Blue HDD | 1TB USB 3.0 Seagate Backup Plus | Edifier M3200 2.1 Surround Sound
  2. #2
    Dec 2010
    Default Re: High Range Wifi Modem
    Quote Originally Posted by rider View Post
    Do NOT get DLink! Repeat - Stay AWAY from DLink.
    You can try tplink w8961nd - should be around 1900-2100... or try Asus/Buffalo..
    Or specify your budget if you are willing to spend higher.
    Lots of networking tuts on this forum - search - ico has a great one I think - for specific problems, you can always post here.
    150mbps or 300 mbps wont matter too much unless you want to build your own internal network (tv pc phone tablet inter-connectivity etc.)
  3. #3
    Aug 2011
    ThinkDigit Forum
    TP-Link TD-W8961N 300Mbps Wireless N ADSL2+ Modem Router review | Modem routers Reviews | TechRadar
    techradar gave poor review for TP-Link One other thing is would I able to connect my portable HDD with that and how it will be able to download torrent stuff? I need help as I want to use this feature.
    D-Link has good reviews and 4.5 star in flipkart rating, why you saying to keep away?
  4. #4
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    If you want USB option then look for Asus RT13NU. D-Link has got many disconnection problems.
    Check [B][URL="http://saswat23.blogspot.in/2012/12/my-computer-peripherals.html"]here[/URL][/B]
    [URL="http://saswat23.blogspot.com"]My Blog[/URL]
  5. #5
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by saswat23 View Post
    How is the range of asus? and how will i use USB HDD feature?
    Asus model has no antenna, how can I trust it will give me performance like D-link or TP-Link.
  6. #6
    Moving dashing.sujay's Avatar
    Nov 2009
    New Delhi
    Quote Originally Posted by dashing.sujay View Post
    No idea about TP Link, but since I own Asus N13U I can tell you about it.
    Some points about it:
    • Router is performing perfectly well, at least for me.
    • No range issues, again at least for me (but I agree it has got bad range compared to other routers in this range, thanks to the internal antenna. But still, I am able to make it work across 3 floors; 2,3(router),4. PS: Range problem should be vertically, if it'd be there, not horizontally, I believe.)
    • Asus firmware is perfectly stable.
    • Download master is working pretty well including p2p.
    • There are all the advanced options which I will or may use. (And probably you too)
    • Finally it will void the warranty if I chose ddwrt.
    Above points also explain why I shouldn't upgrade to ddwrt.
    Now reasons why I should upgrade to ddwrt.
    • You must have read that Asus firmware is buggy, but the actual culprit is DM
    Reasons >
    • It doesn't supports resume after a power cut, you have to do it manually.
    • Plus it supports only FAT32, can't say about ext3. That means I can't download files > 4GB. So think, what's the purpose of p2p download, if you can't DL > 4GB files ?
    Still, its good or arguably best in this range.
    PS: I'm still DLing 24/7
    For faster WLAN transfers.
    > Go to router's setting page (192.168.1.1), enter id and pass (look for default id and pass in manual).
    > Under wireless settings, there will be options to give a password, chose encryption level (WPE, WPA, WPA-PSK,WPA2-PSK), choose the last.
    > Save it.
    > More security can be done by hiding SSID and enabling mac filtering. (normal users won't need it tbh)
    Rules !!
    DropBox: Get .5GB free
    Vaio CB35
    Prized possession
    Asus U32U ATH M20 Asus RT-N13U B1 Razer DA Young Duos
    Vaio CB35 Review
    How fast can you type?
    Quote Originally Posted by axes2t2
    Before working on a master piece you have to first master the pieces.
  7. #7
    Dec 2010
    Techradar's review is more than a year old. The firmware has been upgraded since then, even the model design itself has changed. Wireless performance (the main negative in the techradar review) has improved a lot.
    Anyway it does not have a USB port. There is a higher version of this product which does - I dont remember the model no. right now but you can check the tplink website.
    You could also use Asus RTN13U but thats only a router, not router-cum-modem. You could use two devices like the 13U and the 8961N or get a single device. Asus' products generally work great when you dump some custom firmware (DD/Tomato/Open WRT) in them.
    Both Asus and TPLink have good wireless range. At least in my experience.
    DLink will frustrate you no end - stay away - forget all reviews - trust what users are saying here - many have suffered.
    Check dashing.sujay's post - if you want 2 device solution.
  8. #8
    Aug 2011
    ThinkDigit Forum
    thanks dashing.sujay and mario
    > Save it.
    As you can see I use to have ZTE-ZXDSL-531B which is modem cum router and that asus one is just a router so this means I need to buy a modem separate? And what do you want to say that the USB? The above reasons
    *It doesn't supports resume after a power cut, you have to do it manually.
    *Plus it supports only FAT32, can't say about ext3. That means I can't download files > 4GB. So think, what's the purpose of p2p download, if you can't DL > 4GB files ?
    is after DDWRT or before? I have to download torrent files that are above 4GB, that's the main priority.
    And for no features of USB how is http://www.tp-link.com.au/products/d...odel=tl-wr841n
  9. #9
    Dec 2010
    Before DD of course.
  10. #10
    Nov 2009
    New Delhi
    No, just use it in repeater "mode".
    I guess you didn't read my post carefully. The above status is on stock F/W, i.e. before upgrading to ddwrt. After you upgrade, all the issues are resolved. But you loose the full 3 yr warranty.
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
  11. #11
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by Mario View Post
    So, i dont want to use ddwrt, it seems to have more disadvantages.
    Can you tell me what device i was using before ( ZTE-ZXDSL-531B ) Wireless N Routers or Wireless N Access Points? Whats the difference?
  12. #12
    Took Off!!! dan4u's Avatar
    Apr 2012
    under your bed!!!
    I've got the D-Link DSL-2750U, bought it to replace the Belkin 802.11g Wireless Router, I wanted more range, as my room is one floor above where the router is. but the dlink has the same range as the belkin when it goes through many walls. I get internet but the status is poor or fair mostly. also the dlink drops the connection randomly for no apparent reason, I have to manually switch it off and on again. the usb does not support p2p, it only supports dlink 3g dongle (bsnl evdo, micromax 3g dongle...etc will not work)........I suggest you don't buy this and look else where, look at Asus RT-N13U as suggested above, its only a router, you can use your bsnl ZTE-ZXDSL-531B as the modem and asus for wireless....
    [SPOILER][B]Samsung Series 5 NP550P Intel® Core™ i7 Processor 3610QM Quad Core , 8GB DDR3 RAM, NVIDIA GT 650M 2GB DDR3, Samsung 840 120GB SSD + 1TB HDD 5400rpm, 1600x900 LED Matte display, Blu-Ray, JBL 3 Speakers w/ Sub Woofer[/B] | Logitech G400 Gaming Mouse | [B]Google Nexus 4[/B][/SPOILER]
  13. #13
    Nov 2009
    New Delhi
    You got it wrong mate.
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
  14. #14
    Aug 2011
    ThinkDigit Forum
    No guys I need a modem cum router. And I found TP-LINK TL-WR841N is good on paper, the only disadvantage is it has no USB? It is costing me 1.7k and the cheapest modem cum router with USB feature TP-LINK TL-WR1043ND for 3.6k.
    I want know the performance of both these devices, how is it overall.
  15. #15
    Nov 2009
    New Delhi
    Why?
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
  16. #16
    Apr 2012
    under your bed!!!
    ^^ how much range do you want?? will there be any walls obstructing the router??
  17. #17
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by dan4u View Post
    I need a wifi that should last 20feets on the main floor and should not drop signal at the above floor, thats why I need a 300mbps modem cum router.
    Why?
    You said that you can not download big files
    And I need a complete modem cum router because I dont want use my old ZTE as modem for some router and thinking to give it to someone. This is why I need a modem cum router like TP-LINK TL-WR1043ND.
    I'm now confused bwteen 150mbps and 300mbps modem cum router. I need wifi range only upto 25 feet and above floor not more that.
  18. #18
    Apr 2012
    under your bed!!!
    the TP-LINK TL-WR1043ND has amazing performance, check out this youtube review, but are you sure you don't need more than 25 feet? because most wireless can work good upto 30 feet with one wall in between, the tp link works good even 60 feet away. so maybe the WR1043ND is more than what you need.
    in the top floor how many walls will there be??
    in my case, when I'm on the top floor hall (i.e right below the router), I get full signal, but when I move to a room away from the hall the signal drops drastically, there are 2-3 walls that come inbetween. but on the ground floor it works fine.....
  19. #19
    Alpha Geek sharang.d's Avatar
    May 2012
    Pune
    ^Mbps does not decide wifi range
    Intel Core i5-2500k|ASUS P8Z77-V PRO|CM Hyper 212 EVO|G.Skill 1600Mhz 4G X 2|Sapphire HD 7870|Seasonic S12II 620W|Corsair Carbide 400R|Microsoft Sidewinder X6|Logitech G400|LG E2381VR
  20. #20
    Nov 2009
    New Delhi
    ^I hope you have read that.
    N13U should cover it. But with good or fair signal, not a big deal though. No drops.
    ......if you don't upgrade to ddwrt.
    Then forget P2P.
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
  21. #21
    Aug 2011
    ThinkDigit Forum
    Quote Originally Posted by sharang.d View Post
    so why people buys 300mbps one? Is there any difference in wifi range of TL-WR841N and TL-WR740N, beside 300mbps and 150mbps respectively?
  22. #22
    Make Way the LORD is Here ssk_the_gr8's Avatar
    Dec 2005
    Old Trafford - The Theatre of Dreams
    @Mario
    me and my neighbour have been using dlink for over a year... what kind of issues have you heard about?
    (Gen.1:26-27) New Testament
    Proper Thread Title is a must otherwise you'll get banned
    FORUM RULES - Updated
    Don't Buy from Sulekha
  23. #23
    Aug 2011
    ThinkDigit Forum
    Then forget P2P.
    Why D-Link DSL-2750U and TP-LINK TL-WR1043ND are both modem cum router and can able to download torrent data, why should I forget P2P.
    And is there any difference in wifi range of TL-WR841N and TL-WR740N, beside 300mbps and 150mbps respectively? Both are wifi modem cum router and having 700 bucks price difference but no USB. I have to use wifi for my laptop and mobile phone, thats it so for this 150mbps router is enough or not?
  24. #24
    Apr 2012
    under your bed!!!
    the antenna does...right?
    D-Link DSL-2750U does not support p2p.
    the TL-WR841N will have better range than TL-WR740N not because its 300Mbps but because it has 2 5dBi Omni Directional Antenna's,
    this is the image given in tlinks site, its pretty misleading I believe
  25. #25
    Aug 2011
    ThinkDigit Forum
    Okay, thanks dan4u! So, you mean TP-LINK TL-WR1043ND is the cheapest option for USB + torrent downloading in modem cum router?
    @Mario
    Explain internal network? I've to use only for laptop and mobile phone, sometimes two laptops.
  26. #26
    Nov 2009
    New Delhi
    @Mario
    Where did you read that TP Link supports P2P ?
    Internal network meant WLAN = Wireless LAN. Greater than WLAN speed, faster the b/w intra-network devices.
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
  27. #27
    Aug 2011
    ThinkDigit Forum
    What are the options for the for USB + torrent downloading in wifi modem cum router? As you said Asus RT13NU is just a router and it needs a modem.
  28. #28
    Dec 2010
    Quote Originally Posted by ssk_the_gr8 View Post
    @Mario
    Heard? Even better - experienced. With more than one model - all sub50$ cheapo ones.
    Issues? Connection stability mostly, random restarts very rarely, etc etc.
    Please don't start a flame war - these are my own experiences, yours may be better - in fact, I would be happy if your's is better
  29. #29
    Dec 2005
    No flame war
    I just wanted to know the issues you faced
    Are there even dlink fanbois lol
  30. #30
    Nov 2009
    New Delhi
    Increase your budget to around 4k, then you can expect some offering. That too you will mostly get only "routers", not modem+router combo. You can buy any simple ADSL+ modem under 1k or even in .5k if 2nd hand.
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
