Results 1 to 30 of 33
09-08-2012, 05:45 PM #1
24x7 Torrent downloading solution. Budget: 3K
Hi guys,
I'm looking for a 24x7 torrent downloading solution, without having to switch on my PC thus eating as less power as possible and reducing my electricity bill. I did some research only to end up confused by plethora of ways to achieve the same.
At the moment, I'm using my medium-end gaming PC+BSNL home UL 750 plan+Dlink DSL-502T router for downloading stuffs.
My budget is around 3K. One option that sounds plausible to me is buying a wireless router with inbuilt torrent client capabilities(such as ASUS RT-N13U?). It should have features such as ability to attach to my external 160GB USB HDD(to save the torrent downloads and transfer it later to my PC/laptop).
I've never set up anything like this before, so, please bear out with my noobish queries here. Is buying a wifi router the best option(if yes, then which model?) or are there better alternative out there in this budget?
Thanks in advance.Last edited by TechnoFan; 09-08-2012 at 06:07 PM.
Woah, woah, woah... Lois, this is not my Batman glass. ~ Peter Griffin
09-08-2012, 07:43 PM #2
Re: 24x7 Torrent downloading solution. Budget: 3K
Get TPLINK TL-WR1043ND router and you can install DD-WRT firmware to make it act as a torrent client. Google it, you get lot of information on the same.
Dell Studio 1555 - Intel Core 2 Duo P8600 @ 2.40 GHz, 3 GB RAM, 500 GB HDD, ATI Mobility Radeon HD 4500 | PC - Intel Pentium G620 @ 2.60 GHz, Intel DH67CL, 4 GB RAM, 500 GB HDD | Samsung Galaxy S Plus - 1.4 Ghz, 512 MB RAM, 16 GB Internal, 8 GB SD
09-08-2012, 07:47 PM #3
09-08-2012, 09:30 PM #4Apprentice
- Join Date
- Nov 2011
- Posts
- 72
Can anyone plz give any link where it can be purchased online?
AMD phenom IIx4 960T | Asus M5A88-M | ASUS - GTX660 TI-DC2(TOP)-2GD5 | Corsair DDR3 4GB 1333Mhz x 2 | Seasonic S12II 620w | Seagate 2TB+500GB 7200rpm | CM elite 431plus |Corsair SP2500//Norge 2060
Stereo Amplifier+Norge New Millenium MK II
Speakers | Asus Xonar Essence STX | BenQ E2200HD | PS3 slim 80gb
09-08-2012, 09:39 PM #5Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,491
TP-Link : TL-WR1043ND : Ultimate wireless N Gigabit Router - www.deltapage.com
online prices are a bit higher.check here to see if any dealer is near your location:
Regional Distributors - Welcome to TP-LINKIs God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
09-08-2012, 09:40 PM #6
Available at ebay.in
09-08-2012, 11:14 PM #7
@ OP - you got a PM
Martial Way - Meditation in motion.
09-08-2012, 11:17 PM #8
10-08-2012, 08:40 AM #9
^^ Wait a second. Isn't Dlink DSL-502T a ADSL router/modem?
So won't buying a Wifi router(lets say TP LINK TL-WR1043ND or ASUS RT-N13U) and using it in conjunction with Dlink DSL-502T modem should suffice?
Also one of my friend strongly suggest to stay away from TP Link routers and buy ASUS RT-N13U B1 for my wifi+torrent needs. Is it advisable to buy ASUS RT-N13U B1? Sorry, but I'm a total beginner in networking area. :/Last edited by TechnoFan; 10-08-2012 at 08:51 AM.
10-08-2012, 11:48 AM #10
TP link routers are really good. Its a VFM product. Cant comment on ASUS routers though.
10-08-2012, 12:04 PM #11
10-08-2012, 12:21 PM #12Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
Can a cheap WiFi Android tablet be used as a 24x7 download center?
And for the OP's setup a USB equipped router is needed along with external HDD right? Can a pendrive be used instead of a external HDD?
10-08-2012, 12:32 PM #13
Ah, thanks. But guess, I'll go with Asus RT-N13U Rev.B1 router as one my friend have a spare one. Is this router good for my needs?
Now, presently I use my PC(Windows 7 Ultimate) with my BSNL 750UL to connect to internet. The internet cable goes the ADSL port in the Dlink modem, one end of the Ethernet cable goes in the Ethernet port in the modem and the other end goes to the Ethenet port on my PC's motherboad. I connect to the internet via dial-up in desktop(PPPoE connection).
I've never set up wifi before, so can anyone post step by step instruction on how to set up wifi using ASUS RT-N13U+Dlink DSL-502T+BSNL 750UL?
Dlink DSL-502T from behind:
ASUS RT-N13U from behind:
Thanks alot for replying along guys.
Yes. And yea, a pendrive can be used instead of a external HDD AFAIK.Last edited by TechnoFan; 10-08-2012 at 12:39 PM. Reason: Typos.
10-08-2012, 12:41 PM #14
setup a home wifi-lan, share internet connection
@mods.. can you unlock the above mentioned thread?the cake is a lie
621311.251521
10-08-2012, 01:01 PM #15
^ Thanks..but a tutorial with screenshot will help alot more. Ok, here - Sharing PPPoE connection, ico has posted instruction for setting up wifi(with screenshots). The steps posted there for setting up wifi will be same for my ASUS RT-N13U B1+Dlink DSL-502T+BSNL 750UL setup?
Also how to differentiate between the upgraded version, that is the B1 version of ASUS RT-N13U and the older version? Is B1 written over the box?Last edited by TechnoFan; 10-08-2012 at 06:36 PM. Reason: Geez, typos
10-08-2012, 01:07 PM #16
10-08-2012, 01:26 PM #17Alpha Geek
- Join Date
- Jun 2008
- Posts
- 610
Hi that would not work out for you. I would suggest to get a NAS from Seagate goflex Home adaptor. it supports both internal hdd and usb drives. That itself comes with linux os and it can be tweaked to run torrent 24/7 with least power.
Try it its the best solution. one of the digit member is already selling it for 2.2k . You can save more. He also customize for you and give a pendrive if you pay 200 more with that plugged in you get the option to download unlimited files round the clock.Intel I5 2500K@4.3GHZ OC : Corsair Force 3 SSD 120gb: GSKILL 8GB 2X4GB 1600MHZ: Asus P8Z68 V: ZOTAC GTX 560TI 1GB DDR5:CORSAIR GS800 :Corsiar 400R :Asus Xonar DX 7.1 AC: NZXT SENETRY2 :CORSAIR H100: LG E2360V 23" : Logitech MX518:
10-08-2012, 02:33 PM #18Apprentice
- Join Date
- Nov 2011
- Posts
- 72
I also have same requirement like OP to download torrent 24x7 without keeping my pc ON all the time..but I m sorry that I m unable to properly understand what all members in this thread are posting. So it'll be much appreciated if anyone tells or gives a link for a easy step by step method for our torrent downloading requirement. And what all is needed like pen drive or extrenal hard drive or modem etc..?? Also wifi is not necessary...wired connections can do..only requirement is to dnld torrent. Hope it makes clear
10-08-2012, 04:31 PM #19
15-08-2012, 01:36 AM #20Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Mumbai
- Posts
- 27
thanks for the info @ saswat23 ..
19-08-2012, 02:05 PM #21Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
What is the difference between NAS and the Asus RT N13U router?
BUMP!
1. Using the Asus router can I connect a pen drive and download all the data to it?
2. Which built-in s/w is used for torrents, and which for direct downloads like Rapidshare etc?
3. Can it perform re-connect like JDownloader on its own?
19-08-2012, 04:28 PM #22
19-08-2012, 05:17 PM #23Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
^Whats the difference between NAS and this router? Its available at FK for 3.2K, is the pricing OK?
20-08-2012, 08:18 AM #24
20-08-2012, 09:44 AM #25
well, this is a nice thread and many people need help with this.
BTW digit can publish an article on setting up a wireless network and most importantly to write on pen drives with routers while torrent download and the bonus is that they tested many routers in a recent issue !
BTW digit can publish an article on setting up a wireless network and most importantly to write on pen drives with routers while torrent download and the bonus is that they tested many routers in a recent issue !Spoiler:
23-08-2012, 07:33 PM #26
26-08-2012, 03:06 PM #27Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 8
Just wanted to say that DD WRT will not work with a modem plus router. So one has to invest in a separate modem and router.
26-08-2012, 10:35 PM #28
27-08-2012, 12:13 AM #29
Linksys WRT54GL
27-08-2012, 01:33 AM #30
16-10-2012, 03:52 AM
15-10-2012, 05:59 PM
15-10-2012, 05:54 PM
LinkBack URL
About LinkBacks
