Results 1 to 5 of 5
06-08-2012, 09:12 PM #1
does modem's brand, quality & features effect internet speed?
Hello,
I recently got a bsnl internet connection installed at my home (512kbps unlimited plan). I bought the default modem from bsnl, and it is some adsl2+ cpe / router , brand name: citi, manufacturer: smile electronics ltd. bangalore. its a simple modem without wi-fi and only one pc can be connected.
my friend has also got the same connection but he is using some costly branded modem with many features and wi-fi capability also and according to him he is getting good ping and better in some areas of working (eg. online multiplayer gaming).
so i have this doubt that whether the modem used in the connection is a deciding factor of incoming internet speed? if yes, please suggest some cheapest good quality modem.
thank you.
EDIT: sorry for wrong spelling in thread's title, typing mistake, its affect in place of effect i used , i can't rectify it now.intel core2duo e7400 2.80GHz, intel DG41TY, Kingston 3 GB DDR2 800MHz, 1TB seagette SATA, 320 GB WD sata, samsung 22x DVD-RW, sapphire AMD RADEON HD 6870 1 GB GDDR5, CM xtremepower 600W, logitech z506, samsung BX2031N, HCL keyboard, microtek 600VA UPS, Microsoft XBOX360 controller, Nokia Xpressmusic 5320
06-08-2012, 09:14 PM #2
Re: does modem's brand, quality & features effect internet speed?
No, modem has nothing to do with speeds and pings, they can improve connection quality, i.e less frequent dropouts and managing to stay online even at worse line conditions but ping and speed is not affected.
Project Halcyon V2.1
2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
06-08-2012, 09:23 PM #3
sometimes the speed drops from 512 kbps to a lower speed, so is the modem responsible in these speed 'up and down' cases or not?
06-08-2012, 09:26 PM #4
No, not unless the modem is broken, but its not a problem I think, because if the modem was the problem then it would just lose the connection, not give low speed, BSNL sometimes have massive issues with their lines, sometimes I get 600ms pings to google india, sometimes 60ms.
06-08-2012, 09:55 PM #5
yes, the same case of ping drop with me, thanks for the clarification.
LinkBack URL
About LinkBacks
