Results 1 to 14 of 14
Thread: Data card suggestions.
20-02-2012, 10:12 AM #1Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
My budget for a 3G data card is <2K, I'll be using it with a few service providers but mostly with Aircel,
It must have a facility to switch between 2G and 3G modes and vice-verse while browsing (important).
Do they normally come with some software to do the above, type number and password etc. ?
20-02-2012, 10:18 AM #2
Re: Data card suggestions.
HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
20-02-2012, 10:24 AM #3Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
^OK, I've never used a data card before, that's why I need to make sure the one I'm buying has what I need.
20-02-2012, 10:50 AM #4
20-02-2012, 12:04 PM #5Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
Lava 730G and Micromax 353G have the same features but the Lava one is cheaper by Rs.400, but there are no reviews of the Lava one
Flipkart: Micromax MMX 353G: Datacard
Flipkart: Lava 730 G: Datacard
21-02-2012, 04:50 PM #6Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
I've decided to go with the 353G, price is 2099/- at Flipkart,
I stay in Bangalore, how much would it cost in SP road?
21-02-2012, 05:09 PM #7
Don't buy these, get a Huawei E1750 or E122.
3G Modem Store- Buy 3G Modems in India-Buy 3G Datacards in India-USB 3G Modem-EDGE/GPRS/HSDPA/UMTSSamsung Series 3 (NP300V5A-S06IN) Laptop Unboxing & Review
Panasonic DMC-TZ10 :hyper:
Office Rig: i5 2320-H67DBL-8GB-160GB 5400
26-02-2012, 04:48 PM #8Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
Just a query on data cards, can you change the mode(2G to 3G and vice verse) without restarting and reconnecting like in mobiles?
Or should the data card be restarted and reconnected to the network?
27-02-2012, 09:56 AM #9
Even though
I have used Tata Photon Plus (CDMA)prepaid for more than a year (before jumping in to 3G sim+ unlocked 3G data card band wagon )
and my wife has a company given Post paid Reliance Net Connect even now (CDMA),
I will suggest you get a unlocked 7.2 mbps data card from ebay.in at a very low price.
HUAWEI E1731/E1732/E1750c/E173 between Rs 1275-1399 (including courier)
Avoid ZTE modems if possible.(Most voda data cards are ZTE)
Avoid BSNL proprietory locked data cards like Bubonic Plague (micromax,teracom,Zte etc)
you have two options
1.Buy factory never locked modems from Letsbuy/flipkart @ rs 1600-2000 .
2.Ebay unlocked data cards ( no 3.6 mbps stick to Huawei 7.2 mbps cards ) below Rs 1400.
Get 3G prepaid sim from a few companies and check signal strength at your home with a small 3 G data pack (Rs 100-100 mb like that)
Then go for 4 GB/6GB/10 GB dat arecharge. average cost Rs 600-1200/30 days.
I have 4-5 data cards lying unused in my house. Then you know I have learnt by trial and error !!
Now I want only 21 mbps data card!!
27-02-2012, 10:22 PM #10Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
28-02-2012, 02:31 AM #11
There is no such thing. If your SIM is 3G supported then your card will work with 3G speed else 2G speed. There is no for restarting.
And moreover consider getting Micromax Data Cards. Though Huawei ones are good too but have only 3 months warranty where as the former has 1yr warranty.
28-02-2012, 04:12 AM #12
if you would like to punish yourself, go for "Idea"
Movie Databases: Free Download: http://www.4shared.com/dir/rjI50qqm/Databases_2010.html
http://shop.ebay.in/merchant/taurusoft.india
28-02-2012, 01:12 PM #13
28-02-2012, 05:04 PM #14Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
Regarding 3g data card
By rijinpk1 in forum NetworkingReplies: 8Last Post: 29-07-2012, 08:16 PM -
Data card and psp
By ruc7618 in forum NetworkingReplies: 2Last Post: 21-01-2011, 12:39 PM -
[Suggestions] Graphics Card Under 12k
By srch07 in forum PC Components / ConfigurationsReplies: 6Last Post: 09-01-2011, 01:57 PM -
Which data card is the best?
By aryayush in forum Mobiles and TabletsReplies: 5Last Post: 24-08-2010, 06:52 PM -
ExpressCard - Data Card and TV Tuner Card
By hailgautam in forum Software Q&AReplies: 1Last Post: 20-10-2006, 12:30 AM
LinkBack URL
About LinkBacks
