Results 1 to 8 of 8
  1. #1
    Apprentice MetallosaurusRex's Avatar
    Jun 2011
    London
    Question How to connect 3G dongle with wi-fi router?
    Hola!
    Well, I recently shifted to a new city. I previously had a wi-fi connection at home, with my own router. Now I plan to get a 3G USB dongle to access internet through my laptop, so that I have the mobility.
    I am planning to get a Reliance Netconnect 3G USB dongle (7.2MBPS). Can I connect it with my Belkin G Wireless Router so that other devices in my home can access internet?
  2. #2
    Fire Lord Sudh4r's Avatar
    Jan 2012
    localhost:2912
    Default Re: How to connect 3G dongle with wi-fi router?
    i think the belkin G router doesn't support 3g cards.
  3. #3
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  4. #4
    Jun 2011
    London
    Quote Originally Posted by ico View Post
    Thanks, this really helped. So there is no way I can connect my USB dongle to my current Belkin router? Any adapters/converters etc.? :\
  5. #5
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Quote Originally Posted by MetallosaurusRex View Post
    nope.
    You could connect to Internet from a computer, and then use that computer's Wireless adaptor to create an Adhoc wireless network where Internet is being shared.
    I don't know whether this will work or not, but give it a shot. Even if it does work, I doubt whether it will be smooth.
  6. #6
    Gaming hardcore pramudit's Avatar
    Dec 2011
    Jhansi
    that will do the work..
    Speed might not get affected but ping will increase...
    I've done this with my friend router...
    Intel Core 2 Quad Q8400 |Asus EAH4350 HD| WD blue 500GB | Intel DG41RQ | 2GB DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
    Samsung Galaxy Y || XOLO A700
    Garena id- pramudit
    My coil Gun
  7. #7
    How to change user title? 6Diablo9's Avatar
    Dec 2011
    Pune
    Sorry for reviving an old thread but I found this solution searching online can anyone try it out and see if it works? I'm planning to buy a tablet and I have a reliance netconnect wireless modem which I'd like to share connection with the tab. I think this was tried using Linux.
    1. first make sure that you are connected to internet through your 3G dongle
    2. bring up the wireless router(i'm using TRENDNET-652 wireless router) check its working condition
    3. connect an Ethernet cable from your laptop eth port to wan port of the wireless router
    4. now that you can see an auto eth0 connection in your network manager edit this connection and goto ipv4 settings tab and change the connection method to "SHARED TO OTHER COMPUTERS"
    5. change the connection type in your wireless router settings to automatic DHCP mode
    6. save the settings in the wireless router and restart it and also restart the laptop
    7. check whether the wireless router is able to get ip from the laptop or not
  8. #8
    Apprentice 50103's Avatar
    Jul 2012
    This Router will solve ur problem.
    Asus WL-330N3G | Router | Flipkart.com
  1. Replies: 15
    Last Post: 25-06-2012, 03:53 PM
  2. Replies: 1
    Last Post: 18-06-2012, 09:38 AM
  3. Replies: 4
    Last Post: 24-02-2012, 09:02 PM
  4. Unable to connect to router
    By vikramk in forum Hardware Q&A
    Last Post: 08-02-2006, 05:17 PM
  5. can 2 bluetooth dongle can connect 2 each other
    By vividh in forum Buying Advice
    Last Post: 14-12-2004, 12:26 PM
