Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 10-01-2012, 09:00 PM   #1 (permalink)
Gamer Forever!
Post Extending the range of my ADSL router
I have a Beetel 450TC1 router provided by airtel. The range of that router is barely 10m. I want to buy a wireless router for around 1.5-2k with a larger range (atleast 20-30m).
I've considered the Belkin Basic Router and the Netgear Wireless-N 150 Router (both for about 1.5k on Flipkart). Which of these should I buy? Is there a better router I can get in my price range?
Using a 17" MacBook Pro
Running Mac OS X Lion and Windows 7 Ultimate
Hardware: Core i5 M540 @2.53GHz; Nvidia GeForce GT 330M 512MB; 8GB RAM; 500GB HDD
thestrategist is offline   Reply With Quote
Old 03-02-2012, 09:16 PM   #2 (permalink)
Neeraj J's Avatar
Post Re: Extending the range of my ADSL router
Hi thestrategist,
If you just want to extend wireless range of your modem why can't you use repeater in Wireless Repeater mode. Netgear Wireless-N 150 is best of these two & also feature-rich in low price band.
Lot of valuable info, quite a few thanks ...very little usage of the Reputation button. :twisted::twisted:
8-) Persevered to use the reputation button 8-)
Neeraj J is offline   Reply With Quote
Old 03-02-2012, 10:31 PM   #3 (permalink)
Gamer Forever!
Default Re: Extending the range of my ADSL router
Thank you Neeraj.
I'd considered buying a repeater, but they seem to be much more expensive and offer a much larger range than I really need. Can you suggest one that fits my budget?
Old 03-02-2012, 11:45 PM   #4 (permalink)
webgenius's Avatar
One option is to flash your router with customer firmware like DDWRT or Tomato. They allow you to change the transmission power in the settings. You can increase the range.
webgenius is offline   Reply With Quote
Old 04-02-2012, 04:36 AM   #5 (permalink)
Airtel modem cum router is wifi g. Get wifi n router, but to take advantage of wifi n standard you need wifi n adapter in you system as well otherwise it will perform like same.
OSxSnowLeopard is offline   Reply With Quote
Old 04-02-2012, 04:26 PM   #6 (permalink)
Neeraj J's Avatar
Smile Re: Extending the range of my ADSL router
Hi thestrategist,
As from your sig. you own a 17" MacBook Pro and it support 802.11n, then why you stick with old Beetel modem, what I suggest you to go for Netgear N150 modem which extend your wireless range and also connection speed is improved using 'n' type wireless.
Also as suggested by webgenius you can flash router firmware as you gain control over transmitted power of ADSL modem which in turn increase wifi range but don't expect dramatic change. Some custom firmware are dd-wrt , Tomato and Shibby mod.
- by kool
