sharing my internet connection for android mobile using wifi
Results 1 to 5 of 5
Thread: sharing my internet connection for android mobile using wifi
  1. #1
    Revolutionary kiranm516's Avatar
    Mar 2010
    Andhra Pradesh
    Question sharing my internet connection for android mobile using wifi
    Hi, i have recently got samsung galaxy s2 and, i wanted to use the wifi of my dell laptop to share the internet connection.
    I have a bsnl broadband connection connected using pppoe, using ethernet and my laptop has wifi, how can i use my mobile wifi to share internet
    I used intel my wifi utility and actually on the mobile shows connected but i cannot access internet
    Could anyone please help me with it.
    Popular Gadget Deals
  2. #2
    The High 5 Flyer sam9s's Avatar
    Jun 2005
    New Delhi
    Default Re: sharing my internet connection for android mobile using wifi
    Need to be clear ...
    1. I presume you do not have a router.
    2. Without the router what exactly do you want .....
    A . be able to use internet on your mobile wirelessly
    B. be able to use internet on your laptop wirelessly
    You would need a router in all probability to use the wifi. You can how ever use your mobile internet (EDGE or 3G) to be used on your laptop wirelessly. There is an option called "Portable Wi Fi Hotspot" on the mobile, if you turn that off your mobile becomes a wifi hotspot which can be detected in any wifi enabled device like your laptop. All you need to do is to connect it then.
    [URL="http://www.sam9snews.com/"][I][U]sam9s Tech News Blog[/U][/I][/URL]
    [URL="http://tinyurl.com/bhexkdw"][I][U]sam9s NEW NAS Project! powered by DS413j!![/U][/I][/URL]
    [URL="http://tinyurl.com/63upg4a"][I][U]sam9s HTPC Project! powered by XBMC![/U][/I][/URL]
  3. #3
    Wise Old Owl mithun_mrg's Avatar
    Oct 2003
    Assam
    Use connectify
    [B][I]Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.[/I][/B]
  4. #4
    Mar 2010
    Andhra Pradesh
    Quote Originally Posted by sam9s View Post
    I don't have any router i use Ethernet connection for internet to connect to my laptop, i want use my laptop wifi as a hotspot.
    If i buy a wireless router can i use the bsnl pppoe connection on both laptop and android,
    Quote Originally Posted by mithun_mrg View Post
    Use connectify
    It's not working correctly bro, the phone is connected but i cannot access the interent, does i need to change any settings in my network connections or any firewall setting
  5. #5
    Oct 2003
    Assam
    i assume ur dialing for internet change the connection type to pppoe mode in the modem & set the userid & password so that it connects automatically then try connecting the phone using conectify
    Download & install connectify
    Click on the connectify icon in taskbar to configure the access point
    WiFi in the field Name, enter the name (SSID) of the hotspot that you create
    Choose a password
    Scroll and select Internet network connection that you currently use to connect to the Internet and want to share via the wireless network
    Finally, click on the Start button hotspot
    The access point is now started and active
    Finally connect the phone
  1. 30-09-2012, 06:59 PM
  1. Sharing same internet connection on 2 PCs
    By slashragnarok in forum Networking
    Last Post: 04-01-2012, 11:30 PM
  2. Help on sharing internet from pc to nokia phone using WIFI
    By seekermay in forum Mobiles and Tablets
    Last Post: 20-03-2011, 11:56 AM
  3. sharing internet connection
    By sravan in forum Software Q&A
    Last Post: 09-08-2008, 09:16 AM
  4. sharing internet connection
    By chahal63 in forum Software Q&A
    Last Post: 23-04-2008, 07:20 PM
  5. Internet Connection Sharing
    By sysfilez in forum Software Q&A
    Last Post: 19-08-2006, 07:29 PM
